Question about Linksys Cisco Small Business WAP4410N WirelessN Access Point PoEAdvanced Security (S7271261)
HOW TOCONFIGER WAP4410N WITH WHITCH - Linksys Cisco Small Business WAP4410N WirelessN Access Point PoEAdvanced Security (S7271261)
Unable to login to WAP4410N using web based administration utility after factory reset. it's reporting as invalid username or password
Please see the Reset the Default Factory Setting please read it the Detail I have a WAP4410n wireless access point, I have reset it to factory default by pressing the reset button for 30 seconds. I am able to ping its default ip 192.168.1.245 through its default ssid "ciscosb" if I configure my static ip was solved by connecting through the lan cable, and setting manually the ip to 192.168.1.0/24 network, and accessing 192.168.1.245 through web, the reason why the connecting through WiFi was working because the management web access through wireless is disabled by default
Thanks
Apr 21, 2015 | Cisco Small Business WAP4410N WirelessN...
What is default IP of CISCO WAP4410N WIRELESS ROUTER
Hello Anonymous,
The default IP address for the router you are asking about is 192.168.1.245.
The user manual direct from Cisco can be found at the link below.
http://www.cisco.com/c/dam/en/us/td/docs/wireless/access_point/csbap/wap4410n/administration/guide/WAP4410N_Admin_Guide.pdf
Take care and have a wonderful night! -Alex K
Jun 10, 2014 | Linksys Cisco Small Business WAP4410N...
Configuring cisco wap4410N
Configuration? What type of configuration / settings would you like to know? Anyhow , just use the link below and it will redirect you to the page of your Cisco Service Manual, where you can see the complete image instruction /setup / configuration of your cisco wap4410N
I am sorry , for the answer that I provided . Since I dont have an idea for the configuration that you needed much better if your going to use the link that provided because its very helpful thanks
Mar 18, 2014 | Cisco Computers & Internet
How to connect wap4410 with pc to confgure
Try disconnecting your Cisco Wap4410 from all other network devices then restart it - it will look for a DHCP server, and when it doesn't find one will choose the IP: 192.168.1.245 ---
Set the TCP/IP settings on your laptop to:
IP:192.168.1.250 / Subnet Mask: 255.255.255.0 / Default Gateway: 192.168.1.245 and connect your laptop ONLY to the WAP4410 using a cat5 ethernet cable ---- you should then be able to load a web config page using internet explorer and browsing to: http://192.168.1.245
-------- I've paraphrased the following info from the Cisco User Support Forum (User Juunda):
"...If you read the administrator guide it states that the WAP4410N will search for a DHCP server first, if the dhcp request times out then will it default to 192.168.1.245 this is done so with a user friendly plug and play mentality in mind. Best practice would be to give the AP a static IP of your choice and in your subnet/network so the fastest way to configure the AP out of the box is to assign a static IP on your pc/laptop in the 192.168.1.X /24 and directly connect to the WAP4410N and give the WAP a static IP, define your gateway, DNS servers and then implement it into your network..."
Sep 06, 2013 | Linksys Cisco Small Business WAP4410N...
My cisco wap4410n won't let windows 7 connect
Dear Romo
i have had lot's of problem with the WAP 4410N
the usual solution was to reset the Access Point
and in some case you have to reset it to factory default and set it up again try change the channel of change the location of the Access point for testing only
yesterday i face a problem with WAP4410 that the laptop gets IP but smart phone /tablet doesn't connect stack when getting an IP with static IP the devices connected
So what i did ,I went to the market and buy a new AP NOT Cisco brand
Cisco devises i lost truest on it
Abdullah Al-Ahmadi
System and Network Eng.
Mar 26, 2011 | Cisco WAP4410N (WAP4410NLA) Pre80211n...
I'm trying to configure my Cisco WAP4410N Wireless-N Access Point and i cant access the login page to do it. My IP is already set to 192.168.1.# so i thought i would be fine but it still doesnt work
Network settings on your computer
right click on lan network and properties go to ipv4 properties and use the following.
IP address 192.168.1.2
255.255.255.0
router defaut in the default gateway settings (mine was 192.168.1.245)
enter that again in the dns primary (dont worry about the secondary)
plug an ethernet cable to your wireless router and type in the default gateway.
that will get you to your logon page.
hope that helps
Nov 03, 2010 | Linksys Cisco Small Business WAP4410N...
Linksys Cisco Small Business WAP4410N WirelessN Access Point  PoEAdvanced Security (S7271261) Logo
22 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
