Question about Samsung LN46D630 46 inch LCD 630 Series TV
How to connect my bose solo to my 2009 samsung tv
I hooked up the Bose solo as the manual directed. I plugged the optical digital audio cable to the correct place on the back of the TV (as shown in the picture in the Bose manual). I then plugged the other end into the optical plug in the Bose solo. I tuned the tv speakers to external. The Bose solo did not give out sound. What am I doing wrong?
    New Friend:
  • 26 Answers
Sounds like you have it set correctly..do you have any other sources than external,(such as audio out) ?If so that should solve your problem...does the system have any other connection outs, such as red white audio cables (LR audio )? You can use them as external when the optical is unplugged...if you get sound you either have a bad optical cord or the output for it is defective..good luck GOD BLESS
Posted on Oct 12, 2017
6ya staff
SOURCE:
bomark2002
Mark Bowens
  • 187 Answers
SOURCE: No Sound on TV??
I would borrow a set of external speakers to see if I could get sound from the sound circuit at all, if not, then it sounds like the repair shop.
Posted on Oct 21, 2007
scousemumble
  • 20 Answers
SOURCE: Samsung HT-TQ85 HDMI Input not working
I rember reading an article stating that the HDMI does not suppory audio
Posted on Sep 23, 2008
Anonymous
SOURCE: best way to connect new system
After trying several ways, we decided the best picture was to run the blue ray (out) directly to the TV (in) with an HDMI and another HDMI from the sat. box(out) to TV(in), then optical audio from TV (out) to receiver (in). This way you don't have to change channels on the reciever when switching from TV to DVD. Remember that HDMI is one cable that supports audio and video. If you are using all Samsung products and want to use one remote, using the Anynet feature, I think it has to be connected with an HDMI. I'm going to try connecting an HDMI too from the reciever to the TV to see if this feature will work. It does with the Blue Ray.
Posted on Mar 01, 2009
Jose Garcia
  • 453 Answers
SOURCE: HDMI outlet seems to be bad/ no picture
u need a main signal board replacement
Posted on May 08, 2009
Anonymous
SOURCE: Gurus, I just bought Samsung Home Theater System which i connected to my Hitachi TV with HDMI cable. I have a Optical Cable going from HT to my TV Optical port. I have another connection from my cable
On the remote control for the Samsung Home Theater System look at the bottom left to a button that says "MODE", those moods change the sound each speaker gives off. if that doesn't work, you might need new wiring because there are other wires that are more durable than the ones that come with it, much better too.
Posted on Jun 03, 2009
How do I connect the Bose solo to my television
At the back of the Bose Solo are three different audio inputs. Optical digital-IN, coaxial digital-IN and Cinch (RCA) (white and red) analog audio-IN.
You should check if your TV has an optical digital-OUT, coaxial digital-OUT or an Cinch analog-OUT connection. you need at least one of these three connections. If not, there is no possibility to connect your Bose Solo to your TV. If you use a SETOP-box to watch TV, you could check if it has one of these audio outputs. If it has, you can connect your Bose Solo the your SETOP-box.
Aug 30, 2013 | TCL L32D20
How can I hook up my Bose cinemate on my Philips HD tv when no there is no Audio out and I want to use it for my dvd player, cable box, and video systems?
You don't need to send audio TO a TV. I's a TV, not a source of anything. Many of us use monitors (no TV speakers). The Bose speakers are presumably superior to the TV speakers so whatever the TV is watching (cable/sat/dvd) shuld have its own audio.
Page 11.
If your TV does not have any audio output jacks, you can connect the CineMate™ speaker
system to the audio output jacks of another source, such as a DVD player or cable/satellite
box. However, you will hear sound only from the connected source through your CineMate
speakers.
http://www.retrevo.com/support/Bose-Cinemate-Speaker-Systems-manual/id/526dj591/t/2/
Dec 25, 2010 | Bose Cinemate Digital Home Theater System...
A ps3 and tried hooking it up with hdmi to the 'vcr' connection on the vs-2 of the bose Lifestyle 48 but i don't get any audio (video is fine). hooked up the ps3 with hdmi directly to the tv and get both...
hook up computer straight to t.v with hdmi cable. then get two aux cables (usually red and white) and run them straight from tv audio OUTPUT to audio INPUT on bose system. them anytime you want surround sound even when your watching tv just press the aux button on the bose system controller. should be perfect.
Dec 27, 2009 | Bose Lifestyle 48 Series IV DVD Home...
Pretty much the same problem
I have the same system. I have a Lifestyle and a Sony TV with a Samsung Blueray player. I also have an X-box 360, plus my pc with all my CDs (I-tunes) plays through my bose. Do this:
1. Use the optical cable for the blueray player to the Bose (AUX).
2. Use a digital audio cable from the cable box (either black or orange output) to the Bose CBL-SAT digital input. (it's a single audio cable)
3. For my PC, I'm using a digital cable from the pc to the Bose. I'm using the TV output because it's empty.
4. For my x-box (which I'm not too happy about) I'm using regular red-white audio cables from Bose TV input directly to the TV audio out. (You can play all of the above through this channel, but don't).
I figured the most important high quality sound should come from the blueray player and from watching regular cable tv. For picture, you should be using all HDMI connections.
Hope this helps.
MC
Jun 26, 2009 | Bose Lifestyle 38 DVD Home Entertainment...
Audio problems connecting ps3 to bose lifestyle 48 system
audio has to connected seperatly.vs 2 is for video connection only..Bose is a ripoff.... u pay all that money and you need a seperate audio connection plus all those wires..it isn't worth it and regret i bought it.
Jun 14, 2009 | Bose Lifestyle 48 Series III System
No audio
I beleive that you have connected the HDMI cable to the TV and that you have connected audio out from the TV to the bose system.(I'm assuming that the Bose does not have HDMI connections) it won't work you will have to connect the Digital Fiber Optic out of the TV to the Bose or Direcly from the PS3 to the Bose. Now if you connect it direclly from the PS3 to the Bose you will have to change the audio settings on the PS3 in Audio out from HDMI to Digital Fiber Optic.
Jun 09, 2009 | Bose 3·2·1 II System
How do I get sound from bose cinemate while watching Bluray with?
You are right I checked the Manual online and there is no Optical in. The other tech was right in suggesting that, Cause it would be the next best thing to HDMI. It only has 1 Analog Audio in, So what I would Recommend is Plugging in all of your Devices to your TV and then 1 Audio cable from your TV to The Bose input. Although this will NOT transfer Digital Audio to Analog Audio. This means if you are going in HDMI then the Audio would most likely NOT transfer to the Bose. In this case you would have to hook up a set of Audio cables (Red and White) From the Blu-Ray to the Bose along with the HDMI. This will leave you with only Audio from the Blu-ray through the Bose. To go a step further you can purchase an Audio Splitter (or Video) then plug your Devices into the Splitter and then 1 cable out to the Bose and just Switch the Input along with the TV. Good Luck!
Apr 29, 2009 | Bose Cinemate Digital Home Theater System...
Can I still use my prologic receiver for my LCD TV ?
optical connection in tv is only input optical connection in receiver is only input will not work.need to connect rca jacks to tv's audio out jacks behind tv to any available input in receiver
Jan 04, 2009 | Samsung HTP-1200 System
Cant get all componenets to work together
Okay so you need to run a fiber optic cable to back of bose system for sound on the cablebox if it's a hd cablebox. If you don't have a fiberoptic connection on cable box then you can use a digital coax audio cable and plug it from cablebox if it has it to back of bose system where the plugs are colored all black under the red and white connections. This cable is basically a yellow video rca type cable. That cable doubles as a video cable and a digital audio cable. But anyways once you plug your cablebox up digitally you need to make sure under the settings or setup menu of cablebox that you go under audio and make sure your cablebox is set to dolby digital instead of hdmi. Especially if it's a scientific atlanta time warner cable box. The bose remote should operate eveything still unless I read your question wrong and your saying it doesn't.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 09, 2008 | Bose 3 2 1 GSX System
Sony Audio Optical Out to Bose Optical In not working
Set the source for Optical-In on the Bose system to TV
Dec 16, 2007 | Bose Lifestyle 28 System
Samsung LN46D630 46 inch LCD 630 Series TV Logo
120 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
