Motorola H12 will not charge. On Initial contact the charge light flicckers for a few seconds then goes out. Contacts appear clean
As the headset is repeatedly charged, the pins on the charger starts to not reach the blue tooth ear piece to charge. I clean the dust around the edges on the contact area and was able to get it to charge
Had the same problem and noticed it worked when held upright....so i hung it from a thumbtack by the ear piece....seems to work so far.
hope that helps.
SOURCE: Motorola Bluetooth Headset MOTOPURE H12
My H12 manual has the passcode as 4 zero's for most phones.
SOURCE: where can i get replacement ear cushions for my
http://www.store.motorola.com/mot/en/US/adirect/motorola?cmd=catDisplayStyle
Now out of stock, but are in/out. Keep checking.
SOURCE: RAZR/bluetooth light/charging problems.
Firstly, the light on my bluetooth when I try to charge it doesn't stay on
Same exact problem.
Same problem.
My H12 worked perfectly for about 4 Months. It just will not charge using either charger option. At first it would not charge on the cradle but worked fine using the case charger. Now neither works. It flashed red for a brief second then goes off of charge. When I press the unit firmly into the contact, it flashes a bit but when I let go it goes back to dead. I like and need this thing to work. Any ideas? I am heading back to the Sprint store. Thst is usually a painful thing to do.
no charge started with carrying case and now with the stand. Pressing firmly on it appears to make temporary contact but nothing sustained.
same problem --it just flashes a bit when trying to charge.
Same exact problem
it jusdt blinks red and then goes out. Very frustrating!!!
Can;t charge , indicator light doesn't work
Same Problem, the red "low battery" light is continuously flashing and keeps flashing when i place it in the charger. The connection is good.
