Viene sempre visualizzato sullo screen
SOURCE: processing auto image adjust appeares more times
open the rear cover there is a trimmer, with a screw drive adjust it by turning right or left; the message will not appears again
1 Press MENU to display the MENU screen, and then
press [=> or <=] to select "System Options".
2 Press [Up or Down] to select "Input Terminal Setting", and
then press ENTER.
3 Press [Up or Down] to select "PC input", and then press
ENTER.
4 Press [Up or Down] to select a specifi c adjustment item,
and then press ENTER to set each item.
5 Press [Up or Down] or [=> or <=] to select or adjust the desired
setting, and then press ENTER.
Adjusting the PC Image
Auto Sync. (for Analog PC Input Mode Only)
For automatically adjusting the PC image.
Yes: Auto Sync. starts and "Now adjusting the image."
displays.
No: This function does not work.
When "Auto Sync." is successful, "Completed" displays. If
not, "Auto Sync." failed.
"Auto Sync." may fail even if "Completed" displays.
"Auto Sync." may fail if the computer image has low
resolution, has unclear (black) edges, or is moved while
executing "Auto Sync.".
Be sure to connect the PC to the TV and switch it on before
starting "Auto Sync.".
OK.
