I bought my Asko front load washer and dryer set used and it didn't come with the manual. I would like to know how to use powdered detergent for this particular machine, do I put the powder detergent in the tray like I do for liquid or should I put it right into the drum before adding my clothes?
In the tray, there might be a separator for liquid detergent, that can be turned up side down or taken out completely to allow the powder to wash down. Powder detergent is much better for front load washers as they produce less suds. Don't use too much, a front load washer (high efficiency) uses much less water and thus needs less detergent
But the powder in the tray. I have a asko washer myself
You should to able to go on line and download your manual
Go to Asko.com Good Luck
Because ASKO washers use less water than conventional top-loading washers, you need less detergent and fabric softener. We recommend that you use a low-sudsing powder detergent only, preferably a high-efficiency (HE) detergent designed specifically for front-loading washers.
**(Liquid detergents tend to suds more, which make them more difficult to rinse out.)**
Detergent - The amount of detergent needed varies, depending on the detergent you use. For high-efficiency detergent specifically for front-loading washers, you should use the amounts recommended by the manufacturer.
Also, the amount of detergent needed can vary due to differences in water hardness. (Refer to the Use and Care Guide for more details.) If you choose to use a liquid detergent, start out with a very small amount, such as one or two tablespoons.
Hope that answers your question, let me know please.Thanks for choosing FixYa for your repair solutions today. Let me know if you need further assistance.
Please take a moment and rate the solution provided for you as well as a testimony if you feel it warranted.
Good luck.
Regards,
Macmarkus :)
I would like to add it is HE and I bought HE powdered detergent.
