SOURCE: Just bought a Toshiba laptop model L655-S5096 for
go to Start, at bottom, START SEARCH, type in recovery
click on the file and and when it opens , follow instructions - very simple , make copy of both applicatiosn and OS, unless they are all together
have several CDs prepared to burn
SOURCE: my toshiba satellite laptop keyboard just quit and
turn off your laptop by hold your power..ten turn on again and try to press f8 when it booting..go to safe mode and restore it by go to all program, accessories, system tools, and system restore
SOURCE: set toshiba L655 to factory settings windows 7 got
Toshiba laptops have what we call the recovery partition. To access that;
If ever the recovery partition is not accessible, you need to contact Toshiba and ask for a recovery disc.
Thank you for visiting FixYa!
SOURCE: Hi i'm trying to take
take all the screws off the bottom (including the screws hidden by the optical drive), turn the laptop over, open it. there is a small strip of plastic right above the keyboard, pry it loose and remove the 4 screws from underneath to release the keyboard. disconnect all the exposed ribbon cables and any other cable connector that you can see. once you've done this pick a spot on one of the edges to start prying it apart. Use a small screw driver or plastic pry tool if you need it. (on this model I started with the top right hand corner.)
SOURCE: how to fix key on Toshiba Satellite L655-S5061 Laptop Keyboard
The keyboard is made that limited to no service can be done, replacement of the entire keyboard is required. Short term solution is use external keyboard if available.
The loop on your Toshiba Satellite laptop refers to the computer not booting properly.
During the loop, the computer will try to boot the Windows operating system and keep restarting over and over again.
This is not a hardware issue with your Toshiba Satellite A106.
The issue resides in the startup files on your computer's hard drive.
You can fix this by running a repair tool that comes with your Windows operating system.
This repair tool will fix your startup disk and allow you to get your computer back up and running.
Insert your Windows 7 installation disc into your computer's optical drive.
Start your computer and wait for it to boot from the install disc.
Choose your language from the menu and then click the "Next" button.
Click "Repair your computer" from the menu.
Choose the operating system you are using and then click the "Next" button.
Click on the "Disable Automatic Restart On System Failure" button to disable the startup loop.
Click the "Startup Repair" tool from the menu and wait for the computer to fix your startup disk.
Wait for the computer to finish repairing your startup disk and then allow it to restart automatically.
Wait for the computer to boot correctly to your login screen.
Hope this helps
How to Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your
Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
or
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
