I am trying to change my NAT settings from strict to open so that I can play Xbox Live more efficiently, but I only want to change this on my xbox and not on my computer. Help? i have a linksys wireless-n broadband router and i have my UPnP enabled and i have the ports typed in for my router configuration but still everytime i get on xbox live and test my xbox live connection it says that i still have a moderate NAT connection when i want a open NAT connection. I have tried everything so can you PLEASE HELP AS SOON AS POSSIBLE!!!!!!
Go to your router admin panel and into advanced settings and set UPnP (Universal Plug'n'Play) to enable. If that doesn't work then manuallyopen the ports on the IP assigned to your Xbox. Opening NAT all the way is never a good thing. it opens you up for attacks. So with the above mentioned solution, either way, you should game on well!! Go forth and frag!!
You need to open all the ports for the xbox live. The NAT of that router model cannot be configured to open. Its just a simple NAT for internet connection.
SOURCE: I have a Linksys WRT160N
try this :
1. Log into the router using 192.168.01. or 192.168.1.1
this is done using a browser window such as Internet Explorer or Firefox.
2. go to Application & Gaming
3. In the box on the right column us wan to enter the device ( example: Xbox)
4. you need to enter the start and end port next ( example: 88 and 80
5. then your protocol ( example: tcp ,UDP, or both
6.the IP address if next
7.check enable
8. then save
9.
here is the site with an example page to configure your
router.http://homecommunity.cisco.com/t5/Wireless-Routers/Xbox-360-NAT-issues-solved-WRT160N-v3/m-p/310658?comm_cc=HSus&comm_lang=en#M163159
SOURCE: How do i change my NAT connection from moderate to open
This one is simple. Find the IP address that your Xbox is assigned by your router, then put it into the DMZ. This also goes for PS3 users who are having trouble with internet access.
SOURCE: Change NAT to open
Have you called linksys regarding this problem? Try this http://technicalsupport.blog.friendster.com
so how do i open all the ports for xbox live
ok once again i have been on the computer and on my xbox 360 trying to get my NAT connection to change to an open NAT connection i have put in all the port numbers in on the routers configuration and i have enabled my UPnP so can anybody be very kind by helping me fix this problem with a few steps AS SOON AS POSSIBLE!!!!! I will be grateful for your help. SO PLEASE HELP ME I HAVE BEEN TRYING TO FIX THIS FOR TOO LONG!!!
but i have opened all the ports. i called xbox live and they gave me the port numbers to do it. and i can connect to xbox live but i still only get a moderate NAT connection. i really need a open NAT connection. Can you please help fix this problem because i am having alot of trouble
