KF600.........had a 2gb micro sd, formatted but it wouldn't allow me to download music. Changed to a 128mb micro cd. It shows all the files i.e sounds, images and the memory manager is showing 0 in use and 123516 free yet when I try to send music to my phone from my pc it says unsuccessful not enough space. I need help before I throw it out the window...........lol
KF600.........had a 2gb micro sd, formatted but it wouldn't allow me to download music. Changed to a 128mb micro cd. It shows all the files i.e sounds, images and the memory manager is showing 0 in use and 123516 free yet when I try to send music to my phone from my pc it says unsuccessful not enough space. I need help before I throw it out the window...........lolKF600.........had a 2gb micro sd, formatted but it wouldn't allow me to download music. Changed to a 128mb micro cd. It shows all the files i.e sounds, images and the memory manager is showing 0 in use and 123516 free yet when I try to send music to my phone from my pc it says unsuccessful not enough space. I need help before I throw it out the window...........lol
You can't post conmments that contain an email address.
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
Stuck on Loading Screen
This usually indicates that the software kernel on the micro sd memory card has become corrupted. It can also happen if the micro sd memory card is overloaded with games, music and video files etc. The solution is to reinstall the kernel software on the micro sd card and ensure the micro sd memory card is not overloaded. Leave about 25% memory free.
download SDformatter and format the sd card with that, place all the files on there, none in folders..
If there are hidden partitions on the memory card, Windows 7 will not allow you to change the partition. So to format use a PC with windows XP or older. You also could format this card in most camera's. For that place the card in a SD adapter and put it in your camera. Let the camera do the format.
When you put the card back in the phone, make sure you first format the card with the phone software. Just to be sure the phone can read and write the card.
You have to put your Micro-SD Card in a Card Reader and plug it into your PC (I have a USB Adapter that came with the Micro-SD Card).
Once you can see the Micro-SD card on your PC, then just drag and drop .mp3 tracks (Not .wma) into the "My Music" folder that was created when you "Formatted" the Card using the Phone Menu.
Note: You CANNOT put your Music into folders within this folder, for some reason the phone will not see them. They must ALL be in the root folder "My Music"
You have to drag and drop only the MP3 files into the music folder. If you have them organized and in folder by artist, drag only the MP3s into the card's Music folder.
I HAD THE SAME PROBLEM AND KEPT ON MESSING WITH THE 4G MEMORY CARD AND FOUND OUT THAT I HAD TO FORMAT THE MEMORY CARD ON MY COMPUTER AND NOW IT READS THE CARD..ON THE SIDE OF THE SD ADAPTER HAS A SLIDING PIECE THAT SAVES YOU FROM DELETING THINGS ACCIDENTALLY BUT IF YOU SLIDE IT INTO THE MIDDLE POSITION THEN IT WILL ALLOW YOU TO FORMAT THE MEMORY CARD BUT YOU WILL LOSE WHATEVER THAT IS ON THE MEMORY CARD AND WILL HAVE TO DOWNLOAD IT ALL OVER AGAIN..I HOPE THIS IS CLEAR ENOUGH FOR EVERYBODY TO UNDERSTAND BUT THIS IS HOW I GOT MY MUSIC AND PICS ON THE MEMORY CARD
Hi. Well the problem is that your songs probably aren't recognized as mp3 files. I have a SanDisk micro SD and I downloaded a CD onto on a program such as RealPlayer or Windows Media Player first. Secondly, I dragged the files from there onto my SD. Try this but if this doesn't work then take out your micro SD and format it to your phone. This will end up erasing all that you have on there and possibly require you to do it many times just as I had to do, t eventually mine did work perfectly. I hope this works.
Yes you can get your space back. Let me clear you first you lost the space due to while system is writing data in your SD micro card it is suddenly ejected or disabled.
You will do this method to retrieve you data back. You will need some things 1. Card reader for SD micro memory. 2. A software called D M comes as Hard disk tool it comes in bootable cds.
You will remove your H D for safe side to protect your hard disk data.
Put your SD card in card reader and start you computer with bootable cd that contains D M software.
When your system is boot from cd run D M and go to option in D M erase all data. This will retrieve your all space from SD. Remember you can do the same thing with Hard disk if there is any bad sector or some space not avalible or disk partion is not able to delete by any softwares.
Hope this will help you, If you have any problem regards this you can reply to me other wise don't forget to make ansewer my thread.
You have to format your micro SD memory card with your phone first before you can download files to it. With the micro SD memory card in your phone. 1)go to menu 2) go to settings & tools 3)go to memory 4)select card memory 5)***SELECT OPTIONS*** ---this will ask you if you want to format your card select YES, if there is a phone password it would be your last 4 digits of your number.
Now eject the memory card from you phone. Now when you put the memory card to your computer you should see the sub menus...my pics..my videos...my music...my sounds. Now all you have to do is just click and drag your music and photos to these folders.
Then when you add the memory card to your phone it will see all the music, photos, etc...
I just got a new LG shine CU720 to format the card you go to settings, reset settings, master clear, memory card, my security code was 0000. Hope this helps someone else looking.
