Usual solution is to update the firmware of the printer. The quickest solution is to use a different printer driver. So if using PCL, try Post Script (or the other way around).
Nov 1, 2011 - So, in our case it seems that the shock / strut itself is totally undamaged (at .... As usual, the "chassis setting service required" message didn't show as I ....All of them will indeed need to be replaced when normal weeping ..... Error codes 0115 and 0201 can be related to a low battery, but 0023 and 0113 ...Missing: oem
1 hour ago - Chassis settings service required error message. 2007 v70R with all OEM shocks and alighnment done about 1K miles later the error message ...
aser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms. Error Code: E100 0000
i have 7410 error call service. i tried to clean everithing en replaced the tone is almost full- still getting the error message.hat can i do. (fs-3900dn)
If the machine is saying "Please Call Service"..you will have to access the Service Call function to determine the exact problem.
Press PROG,*,6
Press PROG to select "service call" mode, then press ENTER.
The Error Mssge will be displayed.
For example Heater Error, Drum Fuse Error, Inside Fan Error, etc, etc...
**Most common( given m/c age.) would be "Heater Error"...which indicates a problem with the Fuser Unit.....if this is the case you will need to contact local Muratec service for parts.
YYYY 106: FATAL ERROR An error has occurred which requires service. YYYY = the general cause. 106 = error number. Try turning off the printer then turning it back on. If this does not remedy the problem, write down the message including the error number 106, then call your authorized Oki Data Service Dealer for service. Note: If you see a series of octets containing letters and numbers scrolling across the display, be sure to write these down also and report them to the Service
Fuser error. Replace fuser or if no-go, Main board.
did you try installing newest drivers from intel/gigabyte website? what you described looks to me as a overheating problem. try running the game with case open. are you running on the integrated GMA graphics or PCI-E graphics card(like geforce, radeon)?
SERVICE REQ. 00020000:NVRAM ERROR
SERVICE REQ. 00020001:NVRAM COMPARISON ERROR
SERVICE REQ. 00020002:SDRAM ERROR
SERVICE REQ. 00020003:FLASH MEMORY ERROR
Problem
Abnormal detection in a corresponding element
Solution
1. Once save parameter to Flash memory card and install it to the printer again.
2. C362DRV board. replacement
Service Req xyyyy A Controller error or print engine error detected. Turn off the printer. Wait at least 5 seconds and then turn it back on. If the error message still appears, write down the error number listed on the LCD panel (xyyyy) and turn off the printer, unplug the power cord, and contact a qualified service representative
