Open the Touchpad software,in the Tray Notification Area, maybe Synaptics, Adjust sensitivity settings. The driver can be found here, select your OS : http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=3747931& ALSO, try HP Support : http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=45841&tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=3747931
SOURCE: touch pad driver.
Uninstall the driver from the device manager, then reboot. The machine will find the touch pad and reinstall the drive automatically. If this doesn't work, check the touch pad connection, they will sometimes work loose ar get a little dirt/corrosion build up. The connection is under the keyboard. At this point, if it's still not working, then it has failed and will need replaced.
SOURCE: left mouse button on touch pad not working
have u tried to check it on the control panel/mouse options.
if its not working though i guess the have reason about that.
SOURCE: hp laptop touchpad mouse problems
IF U HAVE REPLACED THE DRIVERS TO THE MOUSE DEVICE THIS INCLUDES ALL THE PROGRAMS THAT THE SITE HAS TO RUN THEM. THEN ITS A HARDWARE PROBLE IN WHICH THE ACTUAL CONTROL FOR THE MOUSE CAN BE REPLACED.
SOURCE: Touch pad on my dv9700 not working
simpletext and mbordolenco are both right. the wires come loose on my hp dv6000 sometimes and I have to disassemble mine sometimes
SOURCE: touch pad driver not loading at boot up
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=468789&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20%C2%BB
seelct your os and downlaod touchpadd river from here then install.
HI,
I TRIED EVERY THING FROM HP SITE, AND I UNINSTALLED THE DRIVER THEN INSTALLED IT BACK AGAIN. IT DIDN'T WORK.
I DON'T KNOW HOW TO CLEAN THE PAD UNDER KEYBOARD. SO IF YOU CAN TELL ME HOW TO CLEAN IT. IF CLEANING WILL NOT WORK, THEN I MIGHT MOVE TO HARDWARE PROBLEM NEXT.
THANKS EVERY BODY
