Machine will fill with water, but will not execute Wash cycle. After it fills with water, I can hear what sounds like a relay activating every 30 seconds or so, but Wash will not start. I can switch the machine to Drain and will successfully empty the water, unlock the door and indicated Finished. It behaves the same on all three basic cycles: Normal, Permanent Press and Gentle. What's the problem?
The brushes in the motor are worn out and need to be replaced or there is a problem with the belt or pulley. This is a fairly easy job and much cheaper than buying the motor. Access from the rear panel. If the belt is OK, remove it and then unbolt the motor, disconnect the wiring and remove the motor. If you are unfamiliar with where the brushes are located, then find someone with a little experience to help pop the old ones out and install the new ones.
SOURCE: Bosch WFX Excel
You have to replace the water inlet valve, the valve where water enters your machine.
SOURCE: bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
SOURCE: Bosch WFF 2001 has finished a wash cycle but the
Do the following.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
SOURCE: Hi. Has anyone experienced bosch washing machine repeating wash cycle?
Hi, I have a similar issue. Did you get a solution?
