Samsung Galaxy Note N7000 16GB Unlocked QuadBand GPS HSDPA WiFi Cellular Phone White Logo
maqsood151 Posted on Feb 14, 2013
Samsung galaxy note hang up - Samsung Galaxy Note N7000 16GB Unlocked QuadBand GPS HSDPA WiFi Cellular Phone White
shariyar khan
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 08, 2013
shariyar khan
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
322
Points
I have samsung galaxy note 1 GT-N7000. and i have a problem in my cell,when my cell is open and it,s prepared network and prepared SD card and after that it hang.even that the touch system is hanged,pls tell me the salution,thank,s
How to fix a hanged Galaxy Note ?
Try stripping the battery out of the phone. Leave it an hour for any residual charge to decay then reinstall the battery.
Also go to. http://samsung.mobile.com/
Jul 19, 2015 • Cell Phones
3answers
Samsung galaxy note 2 locked on at&t
Hi, You can unlock your Samsung Galaxy Note II locked to AT&T network safer and easier using unlock code. You can get the unlock code for a Samsung Galaxy Note 2 from www.wickedunlock.com at affordable cost with easy unlocking guide.
Hello, i just got a new galaxy note but it keeps tripping off on its own even when fully charged. what can i do pls?
your galaxy note must be hanged ,firstly you must be off your galaxy note for sometime then when you note on you setting the portion of according to galaxy note cataloge.
2helpful
4answers
Samsung galaxy note
First you have to get unclock code then you have to follow these steps
  1. Switch ON your Samsung Note with a non Allowed SIM Card, IE A simcard from any carrier besides the one the phone is locked to
  2. Your phone will now prompt you to enter your Unlock Code
  3. Enter the Samsung Galaxy Note Unlock Code sent to you via email and click OK
  4. Your phone is now unlocked !
For any other suopport check at Samsung India site
Samsung Galaxy Note Latest Galaxy Note 4 Note 3 II Price Smartphone...
9helpful
3answers
Android vimicro logo stuck on screen
ANDROID Tablet Freezes at Android startup screen
For Superpad VI - 10.1" Android Version 4.03, this worked for me!
1. Press & hold START button
2. When "VIMICRO" appears, Then Press & Hold the MENU button
3. The Android System Recovery <3e> Menu should appear
4. Scroll down using the Volume Key to "wipe data/factory reset"
5. Press HOME Button
6. Scroll down to "Yes - delete all user data"
7. Press the HOME Button
At this point the system will do a recovery and hard start, and will be on "reboot system now
8.Press the HOME Button
Your system should reboot normally, but you will need to enter all new data, as it has been wiped clean.
5helpful
How do i unlock my pattern lock on my galaxy s2
1. try entering null as password.2. try entering your username without @gmail.com3. Combine 1 and 24. Call yourself from another phone, answer, without hanging up press the home button, then menu button, settings, try to disable pattern-lock5. Call yourself from another phone, answer, hang-up, directly after hanging up start pressing your buttons like a madman for <30-60 seconds ending with your home button (might take a while to get the timing right). Go into settings and disable pattern-lock.6. Try the normal recover password routine from GMail.com
7. Perform a factory reset. YOU WILL LOOSE all not-synced DATA (SD card will be left untouched).
1-6 are possible workarounds, these doesn't work for everyone but can be worth a try to avoid factory reset. 6. is what should work but hardly never does. 7 - The factory reset always work
Added reference with some additional info, how to factory reset can be found there.Good luck!
4helpful
2answers
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
