Unhook everything hook it back up make sure your on the right channel.
Sorry this did not work it has been coming off and on but that has been happenning i got the HDMI cable ferom gamestop and i dont know whats wrong.
I think I found out what is wrong. a Meteorite is passing between the earth and an important cell phone satelite and it is causing problems related to mine i will post later if this is still happening or not so keep in touch.
I just got a new hdmi chord and it still dosen't work. what's wrong is it my TV or my Xbox
SOURCE: connection of xbox360 to sony bravia kdf-e50a12u rear projection tv
http://www.avforums.com/forums/showthread.php?t=384717&page=8
3/4 down the page it tells you how to fix it
SOURCE: xbox 360 has no video or sound on startup
I've fixed that problem several times now with a great xbox 360 repair guide
SOURCE: XBOX 360 no video after playing HALO 3
Yeah, mine did the same thing.
I looked around and it turns out that this problem is pretty close to same thing as the red ring of death, so in theory, to fix this problem you can do the samething as you would do for any RROD.
Last night I did the towel trick and fortunatley it worked for about an hour, than the tv screen went fuzzy and then black. I tried towel trick again for the ful 20 minutes and it seems to be working.
Hope this helps anyone, and wish me luck that my xbox holds out untill I get enough money to buy a new one or a PS3.
SOURCE: xbox 360 video output not working
We can fix this for you. It is the same problem as the 3 red lights. We have fixed several of them with this problem. We are a listed repair service on this site. www.videogamerepairservice.com
$49.99 for one year repair warranty service!!
SOURCE: my xbox 360 has sound, but no video...no red
Hi byersjessica,
Sorry to hear about your xbox issues but their is some hope.
Xbox 360's have had numerous problems since the beginning.
All of the problems come from the motherboard or more specifically components on the motherboard that fail due to bad design.
One thing you can do to remedy the problem(atleast for a little while) is to heat your xbox 360 up.
When you heat the xbox360 it reflows the cracked brittle solder. Thus fixing the broken contact.
I have fixed many a xbox 360's with just a towel.
What you do is wrap the towel around the xbox in a way to cover up the exhaust ports. You don't want the hot air to escape your xbox.
So wrap your xbox with a towel securly(I use two towels) and then turn it on and wait about 5 minutes.
Turn your xbox360 off and let it cool for 10 minutes. Then turn it back on and play some games.
Their is a bad side to this. The more you do it the harder it is on the internals of your xbox. And overtime this fix will quit working.
Their are permanent fixes to your problem but they are quite involved. You would have to take your xbox apart remove the motherboard, remove the heatsink, reapply thermo grease, use different screws to secure the heatsink among other things.
If you want to go that route I would be more than happy to point to sites that have detailed info on this. Actually if you go to youtube and check around you can find great video's on how to do this.
Well I hope this helps and if it does please give me a "fixya rating" to help me out,
AadoubleA
