Continue to press the MODE button until the second digits blink.
Click the START button to reset the seconds to zero (00).
Press the RESET button and the minute digits will blink.
Click the START button to set the minutes. Hold down on the button to increase the speed.
Press the RESET button and the hour digits will blink.
Click the START button to set the hours.
You can select between 12-hour and 24-hour display modes. A "P" indicator signifies it to the afternoon 12-hour setting, a "A" indicate in the morning and a "H" means that it is the 24-hour setting.
Continue this pattern to set the day of the month, month, and day of the week, respectively. 9 Press the MODE button to finish and exit.
if it is the Batman watch that has a secret screen that lights up when you pushed the bottom middle of the watch face this is what worked for me.I call that secret middle button the mode button. push and hold that secret button on the watch face until the hour side of the time starts to blink. let go when you see the hour blink and then you can keep pressing to change the hour. to change the minute I let it go back into sleep mode then press and hold the secret button on the watch face and when it starts to blink let go for half a second and then press down and hold that button again and a minute numbers should start blinking. when they start blinking let go and then push once for each minute. it seems once you start one of these cycles letting go for half a second and then pressing and holding the mode button works. you'll have to experiment with how long to let go and then push.
Buttons are numbered as followed: Start/Stop is button 1 Lap/Rst is button 2 Indiglo is button 3 Mode is button 4
a) Press 4 to select "TIME" mode b) Press 2 and hold for 2 sec to select "SET" mode, second digits blink. c) Press 1 to reset digits to 00. d) Press 4. Minute digits blink e) Press 1 to set minutes. f) Press 4. Hour digits blink. g) Press 1 to set hours. h) Follow same patter to set day of month, month, etc... i) Press 2 at any time to retain set values and exit procedureSource(s):Timex instruction manual
Lap/Rst is button 2
Indiglo is button 3
Mode is button 4
Press mode button till the seconds window blinks. Press Lap/Reset button once to make minutes blink. Cycle through minutes using Start/Stop Button. Press Lap/Reset button once again to make hours blink. Cycle through hours using Start/Stop Button to change the hour
G-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. To set the time, press and hold the the upper left button until the seconds unit blinks on the display. Reset the seconds to "00" by pressing the lower right button.
Push the lower left button to switch to the hours unit, which will start blinking. Advance the hour by pressing the lower right button. If you hold down the lower right button, it will advance the hour unit at a higher rate of speed. Once the hour is set, press the lower left button to switch to the minutes unit. As with the hours unit, pressing the lower right button will advance the minutes and holding it down will advance the minutes rapidly.
Once the time is set, press the upper left button to save the setting.
Backlight
The backlight on a G-Shock watch has a manual control and an automatic function that will light the face of the watch whenever the alarm, countdown alarm or hourly alarm ring. To use the manual backlight, press the button on the bottom of timepiece. The light will glow for approximately 2 seconds before going out.
The automatic function is set by pressing and holding the lower right button. When the automatic function is set, an indicator icon will display on the watch face above the seconds unit. You can turn off the automatic backlight function by pressing and holding the lower right button until the icon disappears.
Note that backlight causes a drain on the battery, and overuse of the backlight will greatly reduce battery life.
Setting the Alarm
The G-Shock has an alarm that emits an audible tone for approximately 20 seconds when it turns on. To set the alarm, press the lower left button until "AL" displays in the upper left corner of the timepiece. Press and hold the upper left button until the hours unit starts to blink. Adjust the hour by pressing the lower right button. As when setting the time, you can advance the hour at a higher rate of speed by holding down the lower right button.
Once the hour unit is set, press the lower left button to advance to the minutes. Use the lower right button to set the minutes. Follow these same instructions to set the month and day you want the alarm set.
When the alarm time and date are entered, press the upper left button to save the setting. Push the lower left button three times to return the G-Shock to "Timekeeping" mode.
Backlight
Setting the Alarm
When looking at the face, you have 4 pushers. Top left is for regatta function countdown. Top right is regatta function start-stop-reset. Bottom left is Hours-Minutes and Nite Lite. Bottom right is regatta function "catch up". Assuming that you want to set Hours and Minutes, press and hold the bottom left for 3 seconds...Hours will start blinking, press the pusher successively until the desired hour is reached. Then wait until it stops blinking. To set minutes, press and hold for 3 seconds, the hours will again begin to blink, then release and re-press for an additional 3 seconds and the minutes will blink, Then press successively until desired minutes have been reached. Stop pressing and wait until the blinking has stopped. Once it has stopped blinking your time has been successfully registered. Good Luck. Hope this helps!
to set the alarm, press and release the "alarm" button; then press and hold the "set" button until the hour begins to blink. press "adv" until the hour AM or PM is correct;now press and release "mode" so that the minutes begin to blink. Set the minutes using "adv"; now press and release "set". Finally, press and release "adv" once to bring up (or remove) the alarm icon. Then press"alarm" once to return to the main display.
To set main display, press and hold "set" until the hour begins to blink; press "adv" repeatedly until hour AM or PM is correct. Now press "mode" so that the minutes blink, and use "adv" to get the minutes right; then press "mode" so that the next item begins to blink; use "adv" to advance until it is correct, then press "mode" so that the next item blinks, and so forth until you're all done. Finally, press and release "set".
Part 1:
Part 2:
(for this part, it's a bit tricky. Hours can be displayed in AM, PM, or 24 hour duration. AM is represented by "A", PM is shown with "P" and 24 hour mode is shown with "H", so keep an eye in the seconds window when setting your hour so you know for sure if you have the right hour)
When your done setting minutes and hours, press mode button again till you get to main screen
A helpful hint is to remember when setting up anything in this watch, mode will cycle through the different screens, lap/reset will change the value of whatever your modifying (AKA minutes/hours) and start/stop scrolls through the different fields.
Hope this helps. Sorry if it's confusing, best I could do.
