19 failures in one day in receivng only, from all companies- codes 420, 412, and 427 are showing but they all say 'check with other party'. Sending faxes seems to be ok.
Check your line for static, should sound a clear tone. 95% of communication problems are related to line quality (phone company fix this). The other 5% is the modem PCB of the fax machine
Apparently, you can set it for the default condition or you
can set it for the current fax you are sending.
To set the default:
1. Press "Function" then "74" then "Set"
2. Press "12" then "Set"
3. Press "1" for OFF
Press "2" for ALWAYS
Press "3" for INCOMPLETE only
4. Press "Set"
5. Press "Stop"
If you want to over-ride the default for the current fax,
1. Press "Function" then "8"
2. Press "1" then "Set"
Press "2" for ON (always print out)
4. Press "SET
Thanks to FixinFax for the clue for the default setting.
