Question about Crosman (4032)
Crosman Powermaster 760 pump bb gun won't hold an air charge
It seems like the gasket is dry so I oiled it hoping it would solve the problem, but it hasn't. Does anyone know what to do?
  • 2 more comments
  • Anonymous Mar 01, 2009
    The problem is the same with mine. i pop a bb down the tube. and i pump air, but no air is being charged. its just the handle moving up and down
  • Anonymous Mar 14, 2009
    i have the same problem also.
  • saddle tramp Mar 20, 2009
    gun wont hold air charge
  • Anonymous Mar 13, 2014
    will not pump
    New Friend:
Take a look on amazon Amazon com Crosman Powermaster 760 pump and take a look for replacement. have a nice day
Posted on Nov 24, 2014
If the rubber piston on the end of the piston assembly is missing, try this:
http://www.usacarry.com/forums/general-firearm-discussion/6931-crossman-66-powermaster-fix.html
If the piston is still there, it may just have shrunk a little due to age or lack of oil. Drive out the roll pin at the top end of the pump tube, then remove the square-drive screw holding the end cap to the barrel sleeve. Be careful not to strip the threads here, since the barrel sleeve is just thin metal.
Remove the end cap and extract the fore-grip and piston assembly. Pull the rubber piston off the assembly and place the cupped end against a golf ball, then compress in a clamp or vise for 15 minutes or so to flare out the cupped end a little.
Check the fit, and if it pumps, reassemble. Worked for me.
Tom
Posted on Apr 09, 2009
  • 3 more comments
  • jeffro-in-NC Feb 05, 2011
    The dismantle instructions worked great. I did take a different approach to expand the rubber piston and clean it and the tube. Once I pulled the piston assembly out of the tube my inspection of the rubber piston at the end revealed the rubber to be an open cup at the end. I cut a slim 1/8" strip of pricing tag (you know, the plastic bar code tags stapled on the end of lumber) and slid it in between the rubber cup and metal piston (this expanded the rubber piston a few microns providing a better seal). I then lightly sprayed the rubber piston with carb cleaner. And, sprayed generous amounts of carb cleaner down the piston tube (up ended to pour out excess. Clean as a whistle! Re-assembled and worked the pump action / press trigger. Also held trigger down while pumping a few times. Back-n-forth until pumping up 3 times fire, then pump 5 times and fire, and then pump 8 times and fire (no bbs, just work it and notice the increased firing sound with more pumps). No more air blow-by hissing. All fixed! Happy shooting! Jeffro.
  • camc5 Feb 17, 2011
    The roll pin at the top of the pump tube won't come out. Is there a special way to get it out?
    I can't get the roll pin at the top of the pump tube out, is there a special way to do it or is my gun just messed up? Any ideas?
  • Johnny sacco Jun 24, 2011
    Perhaps you may have all ready managed to repair your gun if not , try this. First the proper terminology is not a role pin , it in fact is a spring pin. Reason being the material its made from is not only durable , its intelligent. Spring steel has properties that able it to return back to its original state , just as efficient as a spring. The hole your pin is in will be somewhat smaller than its dia. ,since it is not completely cylindrical but rather rolled its entire length the pin has give. This means the right sized hole will except the pin with some force . Once hammered in ,not beaten the pin tries to expand allowing it to remain tight. To remove it , its almost opposite. Never hold the cylinder in a vice the slightest damage to its factory machining will destroy it. Best lay it flat on a heavy bench , many work shops will have holes drilled thru benches for project's such as this. Place your workpiece over top the hole so that when it punches thru it will land on the floor. Now you'll need to find a punch , sizing is important to small it will get knocked it to the pin center expanding it and making it more difficult to remove. To large it will ride on the o.d of the drilled hole. line your punch up over the pin and tap with a hammer , some force may be needed. If you are able to fit the punch into your hole with out force , your on your way. Before you put the pin back in clean the pin up with fine sand paper round both end's as a lead in , just in case they were mushroomed when being removed. Good luck.
  • Matthew Kurtz Jan 05, 2013
    Do you know how to take apart the piston?
Never use oil on the gun it will destroy the seals use automatic transmission fluid.If you go to Colemans web site and look up service centers you can call and get a seal kit for the gun for less than $20 and rebuild the whole thing.
Posted on Oct 09, 2009
    New Friend:
    Problem Solver:
  • 8 Answers
I think it might just need oil . just get a fine air rifle or gun oil and put 4 or 5 drops in the plunger, and 2 or 3 in the place the trigger locks it back ,
Posted on Jan 17, 2011
    New Friend:
By the way, I just took apart my 760 (2nd variant) and looked for a seal kit to replace everything. Kinda overpriced almost everywhere. I called the Crosman co. They patched me through to their customer service...I got the following parts for around 14.50 (that's with shipping). 130-034, 130-035, 140-058, 130-057, 1400a029, 1322D020 (used to be C, but they changed the part # to D) the following part were obsolete - 760-050 (brass nut goes on the bolt action), 760-037, 111a026 (standard spring). Hope this helps.
Posted on Dec 30, 2011
    New Friend:
Power master 760 won't pump at all. Is there a repairman in my area of 45385
Posted on Dec 11, 2009
6ya staff
SOURCE:
My granddaughters 760 pump master will not hold air pressure. When you pump the handle it makes a funny noise such as rubbing the side of a ballon filled with air. The BB just falls out of the barrell. Can...
Hello, I'm not sure why you wrote under this other guns listing. The Crosman Phantom .177 Caliber Break Barrel Air Rifle is a single break action pump and it only shoots Pellets. also much nicer than the 760 pump master, but, it also costs more than 2x's as much.
as for your problem with the 760. sounds to me like it was not maintained well. If You have tried this already ( Crosman Pellgunoil® Air Gun Lubricating Oil ) and it did not work. You can assume that little BB gun is probably broken, the air compression chamber have popped a seal most likely.
if You haven't tried that, oiling the gun then I suggest doing that and maybe it's not too late. There really isn't a lot to be done on these cheaper models of BB guns.
if the BB gun is not years old, just purchased, and Amazon buy, or something else cool like you have a wal mart receipt for it or even if you don't have a receipt and you just want to exchange it. ( i will explain that in a minute ) then I suggest you try sending it back.
If You bought it at a store`, you don't have a receipt. do this if you feel you did nothing to deserve this broken gun.
go back to that store and buy another one, exactly like that one. with cash or card. save your receipt, take the gun home, get it out of the package and use it and take care of it according to the directions. in a day or two take the broken one and the box from the new one back to the store and tell them you want a refund and they will credit your card back Or if you paid cash they will give your cash back. This method of return eliminates the possible bad mood or cranky manager that COULD turn your request down because of no receipt.
This is a great answer to your problem isn't it? :O) Hope it helps.
Mar 09, 2015 | Crosman Phantom .177 Caliber Break Barrel...
93 Paseo compression 130/50/50/125
check the coolant flow,you know,how in detail it flows. I had a car,Buick I think, that cooling was entering the cylinders,so I checked in total detail how coolant flows and found out it WAS NOT the head gasket but a plastic piece the covered the valley (covered the top of the engine)and it was broken (from wear??)so when I replaced it (some seals),it solved the problem. I'm glad I didn't take the heads off ,machined them,replace head gaskets.....etc. Hope I helped.
Dec 21, 2013 | Cars & Trucks
Went to start my XL500 homelite chainsaw and the rope won't pull out.It worked fine when I ran it dry for storage, now it seems like th sprocket won't turn. looks like chain oil is comming out
If it is bar oil then the gasket is leaking between the oil tank and the crankcase, this would mean a full strip down and replace the gasket.
Feb 10, 2013 | Garden
Oil leaks from a freelander 2002 V6 2.5L engine block. I am told dorman Cup expansion plug/freeze plug spoiled. How do I solve this problem?
where exactley is it comming from is it from the rocker cover or the sump either way a new gasket will be needed check hoses around the carbs as well and cylinder head as gaskets can go but not all together but you get oil seaping out of cylinder head hope this helps ivan
Sep 25, 2012 | 2002 Land Rover Freelander
Well i got my car serviced yesterday, an i checked my oil today an it had no oil on the dip stick. Also, it doesn't seem to be leaking from the bottom. Another problem the vacuum has dry rotted in two...
it is possible that when the vehicle was serviced they may have forgot to put oil in the engine,also check if the sump plug has been put back in, as for the perished hose they apparently didn't see it or just could not be bothered to do the job properly, the first thing I would do would be to contact them & complain about the job that they done, the second thing would be to find a mechanic that I could trust to do the job properly.......hope this helps....... cheers.
PS. don't forget to put some oil in the engine.
Sep 09, 2011 | Dodge Intrepid Cars & Trucks
I just got my son a crosman 760 pumpmaster bb gun and we cant figure out how to shoot it. we loaded it, but for some reason it isn't shooting the bb's out
Are you pumping the gun??? Once you have bb's in the gun you have to **** it and then pump the foregrip 10 times then pull the trigger.......
Apr 24, 2011 | Sport & Outdoor - Others
Is there supposed to be oil in with the spark plugs
No this is not mormal. I am assuming you are saying there is oil on the outside of the spark plug and not on the electrode when you removed it. If you have oil on the outside of the plug your valve cover gasket is leaking. Try tightening the valve cover down ever so slightly. DO NOT over-tighten. If that does not work then the gasket will need to be replaced. Unless it is leaking lots of oil, you may just want to live with it as it is expensive to pay someone to replace the valve cover gaskets.
Mar 04, 2011 | Daewoo Leganza Cars & Trucks
1996 Toyota Celica. Oil warning light came on two weeks ago. Topped up immediately with 2L. Have driven the car minimally since. Today the warning light came on again. A kind neighbour checked it and...
Double check coolant to make sure you don't have oil floating on top. It's either an exterior leak, which would mean head gasket or valve cover gasket or it's an internal leak which would also mean head gasket. It it was burning that much oil in that a time, it would run poorly and you'd most likely get a check engine light.
Jul 26, 2017 | 1996 Toyota Celica
I work the lever to load one BB. then pump 6 or 7 times. BB will not shoot out. When I pull the trigger, it sounds like it is shooting, but no BB comes out. this is for a crosman 760 pumpmaster. it...
Can you see through the barrel? Or run a rod down the bore? It sounds like the BB is either falling out the end of the barrel or the BBs are getting jammed up in there. Do not hold your hand in front of the barrel to see if any air comes out. You might get stung with 10 BBs. Hope this helps.
May 22, 2010 | Crosman ® Quest cal. Air Rifle with 4x32...
I WANT TO CHANGE THE AUTOMATIC GEAR OIL, HOW DO I
the filter kit comes with a new trans oil pan gasket you have too remove the pan some filters will pop off some have a couple small bolts or screws before you put the new gasket and pan back on make sure the suface of the trans where it bolts on is cleaned and dry use a razor too scrape it clean then dry it if they dont make a gasket use ( ultra grey RTV gasket maker ) the regular black rtv wont hold up however if your not machanicaly oreinted I would advise seking assistance from a proffesional auto service tech for that job
May 18, 2010 | 1994 Mazda 929
Crosman (4032) Logo
23,865 people viewed this question
Top Crosman Optics Experts
raysaw
Ngoro
Are you a Crosman Optic Expert? Answer questions, earn points and help others
