I don't have my hostname or ip address to continue installing the printers drive? and I don't know from where to get it! help me please
SOURCE: Revised IP address for Ricoh 2020d
Go to user tools counter. Go to settings. Go to interface. You should see the IP address settings window. Some Ricohs have auto DHCP. Usually I turn that on to get it to recognize your router. Make sure your gateway address is inserted as well.
SOURCE: ricoh aficio 1045 error e990 please help it
Error 990 can be cuased by many things. Most of the time it is related to the Hard Drive. you could try replacing it.
SOURCE: Ricoh Aficio 1232c is flashing SC 792
that appears to be a finisher communication problem. Check the connectors..
SOURCE: error code SC 546 in Ricoh 2045e
It's fusing unit but the thermistors connection can be good, but check do they are touching the surface of the hot roller and check do on the side where they are in touch with the surface of the hot roller has some attached toner on them.
SOURCE: RICOH AFICIO MP2000 Printer Scanner Unit HARDWARE INSTALLATION
www..ricoh.com it will helpyou
www.manualsforyou.com
try it.
if you didnt find it
[email protected] mail me
