SOURCE: Reebok Vista belt not working properly
There could be 3 different problems with this machine.
1) loose drive belt (this model has a spring loaded idler that tightens the tension)
2) Bad front drive roller (you wil hear the pulley spinning freely on the front roller if the roller is bad)
3)Last is possibly the walk belt itself. May need to be tightened or replaced.
To try to tighten the walk belt, go to the end of the walk belt and find the 2 adjust allan screws in the end and tighten them 2 revolutions clockwise on both screws.
Hope this helps a little. Tim
SOURCE: hello,my reebok i-run treadmill belt is not moving
Usually a spark means you have a problem with either the drive motor or motor controller board became damaged. Unplug unit remove the motor shroud physically inspect the motor and board for any signs of arching then replaced the board. Next use a multi meter to check continuity of the drive motor by removing the red and black leads that attached to the board if a reading is much more than 1.0 to 2.0 ohms then your motor is also damaged need to be replaced.
