Question about Sennheiser RS120 Wireless Headset
I have no instructions
I just bought this sennheiser rs120 wireless headphones and I dont know how to hook it up.
  • indigohill Feb 13, 2009
    Thank you for the web site. But for some reason it still wont work. I wish they would be more explicit with their instructions. I hook it up to my T.V. and I get nothing but white noise. And I dont know what the other cable hook ups are for.
  • 520 Answers
Here's the link to the user guide.
http://www.sennheiserusa.com/newsite/pdfs/RS_120_US.pdf
Posted on Feb 13, 2009
6ya staff
SOURCE:
How do I get sound to my Sennheiser RS120 wireless headphones when it shows as working properly?
Dirty volume control on headphones. Try moving the volume control back and forth several times to clean off the contacts.
Dec 14, 2014 | Sennheiser RS 120 Consumer Headphones
Should I hook it up to my cable box or tv?
Hook it to the TV. That way if you play a dvd you'll hear it. Cell phones will interfere, as well as cordless phones, so there's not much to do about that.
Nov 17, 2014 | Sennheiser RS120 Wireless Headset
No power sennheiser rs120
Probably a defective item, Try for a return.
Oct 13, 2014 | Sennheiser RS 120 Consumer Headphones
My RS120 will work fine but in about 10 minutes they have no sound. K
see if the sound drivers are wll installed and if it happens with another headphones
Jul 27, 2014 | Sennheiser RS 120 Consumer Headphones
How do you connect the Sennheister RS120 Wireless Headphones to Samsung Smark TV?
You should have either a digital audio out port in the back of your tv or color coded analog out ports. Are you sure you have the cables plugged into the appropriate ports? I made the same mistake when hooking mine up, sometimes the print identifying the ports is very small. Also, since the headphones are wireless you may be receiving some kind of interference from somewhere. If you live in an apartment complex or next to a power substation that could be an issue.
Jan 02, 2013 | Sennheiser RS 120 Consumer Headphones
How do I charge batteries?
The headphones will automatically charge wirelessly when placed in the cradle that should have come with the package. To make sure the headphones are placed correctly, a red light should illuminate letting you know they are being charged and are properly placed.
May 03, 2011 | Sennheiser HDR 120 Consumer Headphones
Sennheiser RS120 with noise...
Couple of things could be going on..
Try the obvious first
1. Select a different channel on the base unit: Located on the front, under the logo is a small switch. Note the position and try the other two settings
2. Make sure your base unit is not next to other items that may interfere with it.. cordless phones and wireless network routers etc.. microwaves or other RF sources .. fluorescent lamps.. etc
Lastly.. just about all wireless headphones have some noise or background hiss.. but it should be minor.. if the rechargeable batteries are not taking a full charge or cannot retain the charge properly.. the reception will also weaken.. and that noise will increase.. and the reception distance will decrease.
You can buy a new set of rechargeable batteries .. just make sure they are exactly like those in your headphones..
If I remember right.. they are Nickel Metal Hydride… (NiMH).. Radio Shack will have them.. or a store like Batteries Plus.. If you replace them.. go for a slightly beefier battery.. a higher mA-h.. may take a bit longer to charge initially.. (If you try this.. remember.. they will need to charge overnight before use) but will “play” longer in use.
It has been noted that many of these headphones shipped with inferior batteries.. that problems seems to have been addressed by the mfg.
Good Luck!
May 17, 2009 | Sennheiser RS 120 Consumer Headphones
RS120 Can still hear TV when headphones are on
Ok.. first.. the simple thing is to go into your television menu and turn the television speaker OFF.
Then exit the menu and turn the volume up.. try your headphones now.
Next.. check the back of the TV for a FIXED AUDIO OUT.. plut your headphones into these outputs.. if you have these.. you can simply turn the set down.. and use the volume control on the headphones.
Apr 08, 2009 | Sennheiser RS 120 Consumer Headphones
Open Questions:
Sennheiser RS120 Wireless Headset Logo
416 people viewed this question
Top Sennheiser Radio Communications Experts
 Grubhead
Grubhead
Michial Gueffroy
Ekse
Are you a Sennheiser Radio Communication Expert? Answer questions, earn points and help others
