No da error de zoom
SOURCE: PROBLEMAS DE IMAGEN
El problema que tienes es de convergencia. puede ser que haya algun componente fuera de valor. si necesitas el diagrama, me puedes escribir a [email protected].
SOURCE: error de sistema (zoom) Lens don't close and
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
Good day,
This tip will explain a few methods on how to try and fix your lens if it is stuck or you get a lens error on your screen.
Please
note that all these methods are used at the users own risk and that I
can not be held responsible for any damages or losses that occur while
trying these methods.
1. If your camera is still under warranty, send your camera to the manufacturer to be replaced or fixed professionally.
2. If your camera is out of warranty try these methods.
If
any of the methods listed above failed to work for your lens problem it
would be wise to take it on to a professional to get your camera
repaired.
Thanks for taking the time to read my tip and feel free to let me know if it was of any help.
Regards
15073327
Antes que nada asegurese de que el dispositivo bluetooth este encendido.
Para poder sincronizarlo:
1. Enciende el PS3
2. En el men? Settings (Ajustes), seleccione Accessory Settings (Ajustes de accesorios) y presione X.
3. Presione X en el icono Register Bluetooth® Device (Registrar dispositivo Bluetooth®).
4. Despl?cese hacia abajo y presione X en el icono Register Headset/Microphone/Headphones (Registrar auriculares/micr?fono/auriculares).
5. En la siguiente pantalla, prepare el auricular para sincronizarlo con la PlayStation 3. Para hacerlo, presione el bot?n K1 durante 8 segundos.
6. Una vez que el indicador luminoso LED del auricular titile en azul y en fecha de comprarojo (lo que indica que el auricular ya se puede sincronizar), presione X en Start Scanning (Iniciar escaneo).
7. Una vez que se haya efectuado el escaneo, la PlayStation 3 reconocera todos los dispositivos Bluetooth que se encuentren dentro del ?rea de alcance del sistema.
8. Busque 8860 en la lista de dispositivos, seleccione el icono correspondiente y presione X para que se le solicite una clave.
9.Escriba 0000 (cuatro ceros) como clave y presione X en OK.
10.A continuaci?n, aparecer? el mensaje: Register completed (Registro finalizado).
