I've installed the 571xp to my truck expecting it to be an alarm. I found that it is basically only a keyless entry/ remote starter. I like the range and the durability of the remote. Is there an alarm system that I can add to my truck that will allow me to use the factory arm and factory disarm output wires of the Python 571XP?
You will need to install another system; a generic alarm/keyless entry system is cheap ; and, easy to install you can find one on ebay
Thank you Jim. Will any of be able to be controlled by the 571xp? Do you have any particular models that you might recommend?
no you disable the eisting alarm system and, install the generic alarm see http://www.ebay.com/itm/AUTOPAGE-RF-425-...
Thanks again Jim. I was hoping to find an alarm that can be controlled by the 571. I've had those other alarms and have not been happy with the quality of the key fob. The 571 can control factory alarms so I was hoping to find a after market alarm that would work. Thank you again.
As a matter of fact. I bought the 571 to replace an alarm like the one you recommended because the fob broke and the replacements wouldn't pair up.
SOURCE: Remote start not working after installation
this could be a lot of different things.... email me at [email protected], and i'll give you my ph# and talk you through it if you want. im an MECP First Class Certified installer with over 10 years of experience, by the way.
