Have completed: Double tap home button, swipe to right, confirm rotate unlocked Powered off, with swipe to power off. ( originally when screen stopped rotating, it was in horizontal, when I did this the first time, it switched to vertical, but still no rotation at all) Pressing home button and power off button simultaneously till apple logo appeared then let go ( was told this is hard reboot and should have resolved issue)
SOURCE: How do you unlock the rotation on an iPad? I've
Use the following steps to enable screen rotation lock:
SOURCE: screen rotation lock is now audio muting. i want
Unfortunately, this is a new feature from a past update. There is no current way to change the lock button back. However, you can access the screen rotation lock by double clicking home, swiping right, and toggle the screen rotation lock. As a future note, in the next update, you will be able to change it back.
To disable guided access try the following:
Triple-click the Home button and enter the passcode chosen during setup of Guided Access to unlock the device
You'll now be back to the usual behavior of iOS.
If you'd like to turn off Guided Access completely, just go back to Settings > Accessibility > Guided Access > and flip the setting to OFF. You'll need to enter the passcode again to do so.
