Start buttons lights up then turns off. If I hold button I can get water to come in and drain out but will not spin. Two months ago start button seemed to get stuck. When jiggled I got it to work.
Hi!
Is it pumping water? If not then pump is bad.
Is the door locking? If the door will not lock, the washer will not enter a spin mode. See if the lock light is lite on the console.
Check for continuity across the Door Lock, Spin Enable Switch when the switch actuator button is pressed in. If there is no continuity across the Door Lock, Spin Enable Switch, replace the Door Lock Switch Assembly.(Check for 120 vac across the Door Lock Wax Motor)
Please rate this solution and ask for further clarifications if needed.
Thanks
Rylee
Did you checked for Door Lock Wax Motor
Then Check for any Broken wires at one of the out off balance switches or a bad switch itself.
If its fine then a fairly common trouble maker has been a burnt diode on the main control board. Generally diode R11 goes bad.
Please look at the link for finding the faulty diode---
Maytag Neptune
(in above figure check the diode R11 above the blue cap.)
Yes the door locks when on spin, does not spin and light turns off.
Yes water pumps out and I can get water to come in.
