What size screws attach the Olevia lcd tv to the stand i called 1-866-9-olevia and was told the top 6 screws are M4x25 and the bottom 2 are T4x10 hope this helps.
The size of the screws used for attaching the TV is M6. You can either use M6X12 or M6X16 screws for attaching the TV. You can purchase the cable from any local hardware shops.
The only things I could think of causing this would be either the hardware not tightened up properly or defective base (stand.) Make sure all the screws are tightened securely in the bottom of the base and in the back of the tv where the base attaches. Someone may have used the wrong screw holes to attach the base but there really should only be 4 holes to use to screw the base to the tv. This may need returend to the retailer for an exchance of the base.
If you pay for shipping I will send you my screws. Maybe a buck or two will cover it in an envelope. I just removed them last night as the TV is being junked for the parts. Email me.
Is that a problem? Check the hole size and choose a screw with a head that is bigger than the hole size. Typically select a minimum of 4mm diameter screw.
There are a number of small silver phillips head screws atteching the base to the back of the set. Remove these and the base will come off. I would suggest that you replace the screws into the back of the set so they won't be lost. I assume you have purchased the proper mounting bracket. If you shop at Wal Mart, they carry two sizes. The 32" will require the largest size. This info applies to what I purchased, which was the 32" LCD flat panel wall mountable unit. I hope I have been some help.....timitot2
