Maytag Neptune MAH5500B Front Load Washer Logo
Posted on Feb 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag Neptun will not agitate or spin
Maytag Neptune washer, top dials (not electronic panel) Water fills and empties, but machine does not agitate or spin. The motor shuts off after a few minutes sitting still in the spin cycle after water empties.
Anonymous
Level 3:
President:
  • Master 1,902 Answers
  • Posted on Feb 14, 2009
Anonymous
Master
Level 3:
President:
Answers
1902
Questions
0
Helped
902253
Points
6294
Change your timer. or timer sensor. behind your knobs
I have a Maytag Legacy SAV515 series top loader. Will fill with water, but will continue to agitate thru to end of wash without a spin, fill, rinse and final spin.
This machine has a 'Fill and Agitate' mode (no spin). So many programs on it! You may have a faulty timer, but due to the cost of those items, I suggest you get professional diagnostic advice. Try a power disconnect overnight. Spin the control dial one revolution and then reconnect power.
https://www.searspartsdirect.com/manual/4j5u0n3o27-003048/maytag-sav515deww-washer-parts
Machine will fill and drain water but does not spin or agitate
could be your door switch, under the top panel, witch you can remove with 2-4 screws on the back of panel. there should be a sheet under panel that will tell you how to get codes by pushing or holding bottons
How to repair water over load on a maytag neptun fav6800w
I don't like using this forum but I will get you started.
You can't get the FAV6800A/FAV9800A Service Manual from this site.
Google this without the quotes""Sticky: Neptune TL Washer FAV6800AWW""" Post your problem at this Forum. You will find the FAVA9800A/FAV6800A Service Manual at that site.
Will the water turn off if you hit the OFF buton on the console or pull the 120VAC power cord to the washer?
Issue could be a Stuck open Water Inlet Valve or improper signaling from the Pressure Switch for water fill in the wash tub.........**** dh1200s
7helpful
3answers
Washer will not spin. Does fill and agitate.
Any error code associated with fail to Spin?
Is this a FAV6800A LED console model or a FAV9800A LCD console model?
Like one of these?
Agitator does not work
Your motor runs in forward and reverse...the spin is one way and the agitate is the other... that direction has failed. Replace the motor...
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
1helpful
Does not agitate, will fill and spin out water. How to diagnose?
take top control panel off and check your lid switch odds are its the problem
Whirlpool top loading washing machine not finishing cycle
SOUNDS LIKE A PUMP HAS GONE BAD. REPLACE IT. IT WOULDN'T COST TOO MUCH.
Matag neptun front load washer wont drain
You have a clog in your pump; have to dismantle to de-clog. Look carefully.
Tip:
Empty out all pockets in clothing before loading the machine!
2helpful
Water will not shut off, continues to fill
does the water run when you unplug the machine? if so then you have a bad fill valve,
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
