My batteries won't charge in the camera or the external charger that I purchased. Also they never held a charge for very long. Should I buy new batteries again or is is a camera issue?
SOURCE: Even with new batteries and they go dead before I take 3 pictures
Yes, there is definitely a fault with your camera. You should be able to return it for a replacement. I wouldn't experiment too much with batteries in this camera. batteries discharging this quickly are likely to overheat, causing unmentionable catastrophe.
SOURCE: How do I replace an Olympus Stylus 710 Battery Door?
Please visit this site and order a new batterydoor for your Olympus camera www.lutoncameras.co.uk
regards Rob NL
SOURCE: Olympus Stylus 1030 SW
Try soaking in a bowl of clean warm water. I had the same problem and this resolved it. gotta love water proof camera!!!
SOURCE: Olympus battery charger flashes red when battery is inserted.
@gminvite1
"Another way I found was when this happens, to push the battery to the
point the light will turn on, when it starts flashing slide it off then
back on. Do this a few times so it charges a little, then you should be
fine to leave it on."
I tried to do this with my LI-10C Olympus charger and it worked..The blinking red light turns to solid red..Thanks for the info...Now I won't be bothering to buy a new batt.or have my charger checked..
SOURCE: battery charger says charged. camera will not turn on
Hi there i can 't get your these word." camera charger is blue, used battery and new,". Please let me know the battery is new or or its old? If its old then the battery life is finished. Thats why he can't store the power.
Thanks.
