If this does not work on any cycle then make sure you have electricity at your outlet as there is no fuse for this unit.
If you have power but it will not work in any cycle then you most likely need a new timer.
If the unit will fill and wash but not spin or drain then you most likely need a lid switch.
SOURCE: Maytag top loading washer will not agitate
My rule of thumb: Take what you paid for the washer new and divide by number of years without repairs. That is your cost per year for the washer. If the repair will get you another year and is less than the number above do the repair. If you have done more than 2 major repairs in a year it is time to think new. eric
SOURCE: i have a maytag washing machine, model
That sounds like the center shaft seals are worn out. If the shaft and related parts are not corroded or rusted, it can be fixed. If it is the tub boot seal, it is a major teardown either way. But that model is worth fixing up if it is in good enough condition, and the cost in your area isn't over $200.
