My tablet turns on but it just stays on the Android logo. It won't boot up past that. Can anyone help me out? I think it may be bricked but im not sure. And if it is, what is a solution for this?
1. Power of the device.
2. Now,Hold down both volume+ and power button simultaneously, you should get an android on its back opened.
3. Press both volume + or - to open up a small blue text menu.
4. Then use Vol - and Vol + to navigate the Recovery mode.
7.)Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
If a factory reset is required. Press and hold both Volume buttons and the Power button simultaneously; an Android logo with an exclamation mark should appear. Press both Volume buttons at the same time to open Recovery Mode and use the Volume Up and Volume Down buttons to navigate.
I will give you the instructions to do a hard reset for the tablet.
Once you do this, you will lose all the data on it and will be just like you bought it. The process is listed below.
Press and hold both Volume buttons and the Power button simultaneously. An Android logo with an exclamation mark should appear. Press both Volume buttons at the same time to open Recovery Mode and use the Volume Up and Volume Down buttons to navigate. Select "Factory Data Reset", press power, choose "Yes" from the menu and press the Power button again.
Where did you get the tablet? I believe you purchased a store demo tablet. If you you browse zeepad's website you can probably restore the firmware and get rid of store demo mode.
I had the same thing happen to my Digix Tab 720 last night. This happened after I reset the tablet to factory settings. I left it charging over night and this morning, it is working perfectly. Hope this helps.
