Try looking up the brand name on your universal remote then look up brand on your preferred search engine it should lead you to a website of remote then through there you most likely can find out some info about the codes. I hope this information helps you out.
If you have removed the base, then remove the speaker compartment which has a lock that holds the plugins part. I repaired a similar tv today at my work shop.
Short circuited component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
This is very common in sharp tvs.U turn it on.U get power on light stable right?U hear a click,one or twice,sometime tv is good right?Sometime POWER light and OPC light flashes?Push the power button on/off couples times will work, picture will come on.If keep trying off/on couples time after POWER and OPC flashes,don't ever stop and never get backlight and picture.Ur Video backlight board is dead must replaced.
Turn off your closed caption and or text mode using the closed cation button on the Magnavox remote or through the TV's menu there wil be an option to do so.
iv'e run into this before, you have closed caption text 1,2,3 or 4 on. this is different than the normal "cc" cation. just go into your menu & turn off closed caption.
