A
Anonymous Posted on Feb 19, 2013
Ricoh MPC 2500 Data in light keeps blinking
Machine will make Copys but the Data in light keeps blinking, I unplugged the Network cable and turn back on and the light kept blinking?
3 Related Answers
jknutson3813
  • 22 Answers
  • Posted on Aug 09, 2009
SOURCE: Ricoh Aficio 1027 network connection problem with vista x86
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
Anonymous
  • 58 Answers
  • Posted on Feb 26, 2010
SOURCE: sc491 error on ricoh MPC 3500
Sc 491 straight from manual
High voltage power: Drum/ development bias output error
An error signal is detected for 0.2 seconds when charging the drum or
development.
 High voltage leak
 Broken harness
 Defective drum unit or development unit
 Defective high voltage supply unit
1. Check or replace the harness.
2. Replace the drum unit or paper transfer unit.
3. Replace the high voltage supply unit.
Anonymous
  • 75 Answers
  • Posted on May 25, 2010
SOURCE: Every light is blinking, toner, drum, paper and status light
a would advise you service the printer...... sometimes dirt and other things can cause it to malfunction
4answers
My ricoh aficio is showing sc819
Bad hard drive? unplug it an turn on unit. -Carl
Why is red light flashing on data?
The copier is detecting a network request. whether there is one still or was one and now it is looping back on that can usually be cleared by unplugging your network ethernet cable then ether clearing your Que or powering down the machine. reverse order and make sure you have a blinking green light on your Network Interface Card NIC what the cable plugs into on the copier side. Obviously tell your office manager you are clearing out the printer Que before you do, there might be something important headed that way. ;-)
How to Fix led touch screen Ricoh aficio mc2500 with heat flame?
If you mean the Ricoh MPC 2500 there was a factory bulletin issued about the touch screen. Contact your nearest Ricoh dealer and provide the machine serial number to determine if it is one of the affected units.
1helpful
Ricoh aficio MPC 2500 sc202.
Very common problem. It's a short in the BICU that takes out the Polygon motor. Replace BICU, and most likely the polygon motor (again)
3helpful
2answers
2helpful
2answers
MY RICOH AFICIO MP C6000 IS SHOWING AN ERROR CODE SC326
That is a "second laser synchronization error". Try this: Hit the yellow button, press numbers 1, then 0, then 7, then hit the orange key. When it goes into SP mode, turn off the copier and unplug it. Wait 15 seconds then plug back in and turn on. If that does not fix it then you need to call a tech to service the machine.
3helpful
2answers
My wlan light keep going on and off on my wrt54g
Also check if the power light on your router is blinking. If it is blinking, that's an indication of hardware failure. To revive it, do a hard reset. Press and hold the power button of the router for 30 seconds then unplug the power. Wait for 30 seconds again before you plug it back in.
2helpful
2answers
How to install a new hdd on my copier Ricoh 2035 or 1035?
Unplug machine, unplug network cable ect. remove the 2 screws that hold the board in (top & bottom) slide assy out remove HDD and put back together being careful not to hit the HDD. Exicute SP 5-832-1 (all) to initilize the HDD exicute SP 5-853 to reload stamp data. ( to enter service mode in sequence hit clear modes 1 0 7 stop, hold the stop for 5 seconds enter copy SP ) -Carl
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
