Sport & Outdoor - Others Logo
Posted on Feb 15, 2009
Trying to finds In-ground basketball hoop part
The Reebok 59971 in-ground basketball system Piston is broken, all the oil leaked out and now the system is un-moveable.
I am looking for a replacement... any suggestions?.
  • Anonymous May 21, 2009
    hi b_larsen,
    do you happen to have your manual for the 59971?
    thanks,
    tyler
alexmrm
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 05, 2022
alexmrm
Contributor
Level 1:
Answers
Questions
0
Helped
651
Points
You can check this guide to make an worthy purchase.
Jan Kennedy
Level 1:
  • Contributor 2 Answers
  • Posted on Jan 31, 2022
Jan Kennedy
Contributor
Level 1:
Answers
Questions
0
Helped
19933
Points
6
I am interested in basketball system. https://ballproguide.com/best-in-ground-basketball-hoop/
Delia Cummings
Level 1:
  • Contributor 4 Answers
  • Posted on Aug 03, 2021
Delia Cummings
Contributor
Level 1:
Answers
Questions
0
Helped
20619
Points
12
Will you be interested in a complete in ground basketball system?
Anonymous
Level 1:
  • Posted on May 05, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
651
Points
I have a Reebok 51781 with a broken adjustment handle. It (and maybe your model) is built by www.lifetime.com. I just emailed them about replacement parts (none listed online). Perhaps you could do the same.
Anonymous
Level 1:
  • Posted on Feb 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
651
Points
Well you can try to contact reebok directly, if not attempt to contact the store at which you bought the system. hopefully reebok will be able to send you a new piston...i believe that the hoop is under waranty
How to fix my basketball hoop
Your either going to have buy a new one which I'm sure you want to be a plan Z. With that said, your going to have to weld it at a position that is not adjustable or is possible weld and screw 2 sides where it can move at the broken angle
May 26, 2013 • Basketball
My basketball hoop broke and I have a pole cemented in the ground. Can you buy just the hoop/backboard itself and attach to the pole or do I have to cut the pole and start over?
Sorry I know nothing about basketball but it seems a crying shame to cut down the pole even if you can't find a replacement hoop and board.
I have faced many similar things and I find remembering the wise old saying "in order to get the right answer it is important to first ask the right question"...
I suggest you ask around those who should know such things - the coach at the local schools, local teams. If you don't get satisfaction then why not ask your local repair shop or fabricator if they can make what you need at a reasonable cost.
1helpful
30helpful
9answers
1helpful
I have a lifetime basketball goal with a broken backboard. My son threw a rock threw it. Can I get a replacement glass? Is it easy to change?
You NEED to get a replacement piece from the manufacturer. You could get a piece of lexon from home depot but it will cost you a bit.
2helpful
2answers
Need an installation booklet for a reebok 59971 basketball system.
The Reebok website is horrible for supplying support material. If you don't have the instruction book that came with the hoop, you can most likely get it online from Lifetime. I'm told the Reebok product is made by Lifetime. Look on their site for the 71525 model and see if it matches what you have with your set. If it does, that book is available op their site.
1helpful
2answers
Basketball backboard problem
well it is probably a cheap backboard then. sorry
Top Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
