The Marathon water heater have a lifetime tank. The heater tank dimentions for MR 50230, 50238, and 50245 are the same. It appears that only the element sizes are different.
1) Product warranty will be voided if you install 4500 watt elements in year-2008 model MR50238 3800 watt marathon tank.
Older 3800 watt element models have been discontinued.
2) Copy following links for Marathon resources:
http://waterheatertimer.org/Review-Rheem-Marathon-water-heater.html
http://waterheatertimer.org/How-to-replace-water-heater-element.html
3) Product warranty is voided if element wattage exceeds label on side of unit.
4) Marathon has a problem with elements burning out frequently.
To solve this problem, they suggest installing element with lower wattage, such as the 3800 watt.
Upper 3800 SP610130
Lower 3800 SP210197
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Thanks, I'm in a rural area and I was only able to find a 3800 element anyway, The unit is about an 06 model so the 6 year warranty is off. The element arced to ground so I knew it was bad. It's working well.
Good job replacing. Older Marathon start to burn out elements, so you might buy a few extras for stock.
