94-00 Ford Econoline Van Side View Mirror - Left Driver 1994 95 96 97 98 99 2000 F4UZ 17683 A Door LH Replace Logo
nilo perez Posted on Feb 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1995 ford e150 ignition system module, where is located? it is not on the distributor...
The van looses the spark from the coil,,but the coil is new,also the wires m, rotor cap and computer, can anyone helpe me on that problem>???
Lawrence Oravetz
Level 3:
  • E Series/Eco... Master 10,558 Answers
  • Posted on Jan 12, 2014
Lawrence Oravetz
Level 3:
Answers
10558
Questions
Helped
2697343
Points
29284
The system gets it's power from the ignition switch.. May want to look at that.
I have a 1995 mercury sable i get no spark it has the 3.8l .it also has a ditribitor and coil packs why am i getting no spark replaced plugs coil packs distributor
Ignition control module ? Is there B+ voltage on the red an lit green striped wire at the ignition coil ? Watch this video on how to trouble shoot . This is a ford pick up ,ignition system similar . 1996 Ford 150 No Start with ScannerDanner EricTheCarGuy
4.6 ford f-150 no fire to plugs
Likely ignition module or distributor some had module right on distributor if this is the case replace whole distributor assembly... check and see if you have spark from coil to distributor also have seen the coil fail as well
2answers
No spark at coil or distributor
I would buy a book with the procedure to troubleshoot the ignition system. The problem could be the pickup coil in the bottom of the distributor among other things. The module uses the pickup coil to know when to fire the plugs. The computer only controls when the cylinders fire.
1helpful
Need specifics [how tos] for 1993 Ford E150 Conv van.351,5.8L,8cyl,[5766]
First, if you have a shop manual for vans you have as much or more info than the folks who answer questions on this website.
A 5.0 engine and your 5.8 are more or less the same, just different size pistons.
A shop manual should have wiring diagrams in the back of the book.
You will need to figure out if you are having a problem with fuel or ignition assuming you have good compression.
One common problem with Ford products that won't start is the EEC relay and the fuel pump relay.
There is a list of options with no spark, including the coil, cap-rotor-wires, plugs, and the ignition module that fires the coil.
No spark 1985 E150 Ford Van
check rotor, also check ignition module on distributor
4helpful
2answers
Where is the Ignition Control Module located on a 1992 Ford E150 Econoline van?
After 1991 ford moved the TFI from the distributor to the left fender next to the coolant bottle under the hood.
3helpful
No spark Told to replace ignition control module where is it located
Your 95 Jeep does not have an ignition control module. This ignition system has a exterior mounted ignition coil and also a pick up switch inside the distributor.
2answers
1990 FORD F 150,SPARK ON THE COIL BUT NO FROM THE DISTRIBUTOR
Replace the wires from the the ingnition module from the coil.
2answers
94 Aerostar won't start. No fire
1 Inspect Battery Damaged or faulty battery and/or connections. here is a list of things u can check hope this helps Shaun 2 Inspect Coil - Ignition Damaged or faulty ignition coil or ignition coil circuit. grey_line.gif 3 Inspect Fuel Filter Clogged or dirty fuel filter grey_line.gif 4 Inspect Fuel Injector Pressure Regulator Faulty fuel injector pressure regulator or circuit. grey_line.gif 5 Inspect Fuel Pump Improperly functioning fuel pump or circuits. grey_line.gif 6 Inspect Wireset Damaged, worn, or deteriorating spark plug or coil wire(s). grey_line.gif 7 Inspect Control Module-Ignition Faulty ignition control module or circuit. grey_line.gif 8 Inspect Solenoid Switch Damaged or faulty solenoid switch or solenoid switch circuit. grey_line.gif 9 Inspect Starter Damaged, worn, defective, or faulty starter or starter related circuit. grey_line.gif 10 Inspect Neutral Safety Switch Damaged or faulty neutral safety swittch or circuit. grey_line.gif 11 Inspect Fuse Corroded, burned, or shorted fuse may be interupting power source. grey_line.gif 12 Inspect Fusible Link Corroded, burned, or shorted fusible link may be interupting power source. grey_line.gif 13 Inspect Battery Cable Corroded, broken or poorly connected battery cable. grey_line.gif 14 Inspect Spark Plug Wire Loom - Performance Improperly adjusted or worn/malfunctioning carburetor. grey_line.gif 15 Inspect Distributor Cap Loose or cracked distributor cap grey_line.gif 16 Inspect Distributor Cap And Rotor Kit Loose, cracked, or worn distributor cap and ignition rotor. grey_line.gif 17 Inspect Fuel System Pressure Incorrect fuel pressure being delivered to carburetor or fuel injection system. grey_line.gif 18 Inspect Fuel Injector Plugged, dirty or poorly connected fuel injector. grey_line.gif 19 Inspect Ignition Switch Worn, damaged or faulty ignition switch or circuit. grey_line.gif 20 Inspect Spark Plug Fouled, damaged or broken spark plug(s). grey_line.gif 21 Inspect Belt Incorrectly routed, adjusted(tensioned), missing or worn drive belt(s). grey_line.gif 22 Inspect Timing Belt Slipped or broken timing belt. grey_line.gif 23 Inspect Timing Set Slipped timing chain or worn timing gear(s). grey_line.gif 24 Inspect Fuel Tank Contaminated fuel from rusted or deteriorated fuel tank. grey_line.gif 25 Inspect Ignition Timing Incorrectly adjusted engine timing. grey_line.gif
1helpful
3answers
1984 Ford E-150 Econoline van It has no spark
Are plugs and wires good? Did you check distributor? Firing order correct-timing set right? Maybe some of the new parts are faulty? Are grounds all secure and are fuses good?
Top E Series/Econoline Van Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you an E Series/Econoline Van Vehicle Part and Accessory Expert? Answer questions, earn points and help others
