Xerox WorkCentre 7425 7428 7435 7525 7525 Waste Toner 008R13061 Logo
A
Anonymous Posted on Feb 21, 2013
10-338 system error
Startup 6 beeps
Probable Causes
Error
Beep Codes
Defective system board.
Memory refresh failure.
Faulty DIMM or defective system board.
Error occurred in first 64 KB of main memory.
Faulty DIMM.
Read or write error occurred in first 64 KB of main memory.
Timer on system board malfunctioned.
Defective microprocesor.
Microprocessor error.
5
Gate A20 failure.
6
Defective microprocessor.
Microprocessor-execption interrupt error.
7
Missing or faulty video adapter.
Video memory read/write error.
8
Corrupted system BIOS program or defective system BIOS chip.
ROM checksum value does not match value encoded in system BIOS.
9
NVRAM shutdown register read/write error.
10
Defective microprocessor or cache card.
Cache memory error.
11
Faulty video adapter.
Video adapter failure.
12
Loose video cable connection or defective video cable.Faulty video adapter.
No monitor connected.
13
Long beep at startup
Probable Causes
Error
Beep Codes
Faulty DIMM.
5
Gate A20 failure.
6
7
8
9
10
Cache memory error.
11
12
13
14
Dell 4 beeps
POST Beep Codes
How to fix Dell BIOS 8 beep error.
Probable Causes
Error
Beep Codes
Faulty DIMM.
5
Gate A20 failure.
6
7
8
9
10
Cache memory error.
11
12
13
14
5helpful
5answers
My computer has a critical error on the adress 0x3BC3, how do i solv it?
It might be a fake error message. Use this code 754-896-324-589-742 to unlock your computer. More information about this infections:
http://deletemalware.blogspot.com/2011/07/system-process-at-address-0x3bc3-have.html
89helpful
7answers
Sir, there is an error i.e system error e225 in my canon mf 4350d machine please help me shut out this problem
Sir, there is an error i.e system error e225 in display my canon mf 4350d machine please help me shut out this problem
1helpful
What is this error mean that i get during boot up? 312.198 Eth0:(185488) System Error Occurred (0) 312.199 Eth0:(185489) System Error Occurred (0) 312.200 Eth0:(185490) System Error Occurred...
I think this is related to to the NIC (Ethernet port).
Go into the BIOS and set it to default settings, see if that resolves the problem.
Let me know how you get on.
Regards.
1helpful
Please help me ??? system error
System Error: 04Cxxx
Problem
Description:
EIO Accessories (EIO Card/Hard Disk Drive) Error.
Corrective Action: Try the following:
n Press ENTER and switch the printer OFF. Remove the Hard Disk
Drive (if installed) and make sure that the EIO card is installed
correctly by pushing it firmly inwards and checking that the two
installation screws are completely tightened. Switch the printer
ON again. If this error code continues to appear then replace the
EIO card.
n If this Error Code disappeared after removing the Hard Disk
Drive, then switch the Printer OFF and reinstall the Hard Disk
Drive, making sure that the two installation screws are
completely tightened. Switch the Printer ON again. If this Error
Code reappears, then the Hard Disk Drive could be faulty.
Replace the Hard Disk Drive.
n If this system error continues to appear after replacing the EIO
card or the Hard Disk Drive, then replace the Electronics Module
System Error: 0000D8 XXXXXXXX (Non-Continuable)
Problem
Description:
External Library Error.
Corrective Action: Refer to System Error Code 070100
System Error: 070100 XXXXXXXX (Non-Continuable)
Problem
Description:
Firmware Error.
Corrective Action: Power the Printer OFF and ON again to see if the System Error
disappears.
If the Error Code reappears, then report the error to the HP response
Center or the nearest HP Support Office, stating the following
information.
n Model and Serial Number of the printer.
n Which firmware revision the printer is using (See Note below).
Check firmware in Utilities / Statistics / Code rev.
n The complete error number (See Note below).
n The Service Configuration Print þ
n The Current configuration sheet.
n Which software application the customer is using (name, version, etc.).
NOTE When reporting the System Error Code, make sure that you
supply the full Error Code (including the last 8 numbers where
applicable) and the firmware version. Without this information,
HP Support Personnel cannot help you.
15helpful
3answers
SYSTEM ERROR - E007 SOLUTION 3
when i switch on the machine, it show a red light with the word system error E007
18helpful
3answers
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
