Followed direction to open and close front door-error code returns. Also hear a vibration sound when it tries to re start
SOURCE: error code S0042, DIMAGE G600
The S0042 error code relates to a problem with the zooming mechanism (lens would not retract or extended)
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. Let me know if it worked!
SOURCE: error code 2152
Trans belt retraction failure. Its a common error that can be reset by opening and closing the front door with the machine on.
Look in the trouble history and if has happened often, better order a new belt.
SOURCE: error code C- 4553
this is a very costly problem. This is a Laser that is bad, in this machine there are 4 lasers (print heads) they are supposed to go the life of the machine, but they are failing all over. i have replace all four in a machine just yesterday. you can try one thing first. Reload firmware, this requires a compact flash card and the correct firmware and a way to load it to the card (using a Konica minolta firmware tool) I can help with all of this if you want to try the firmware first... if not then its a set (yes all 4) print heads and they are spendy. But they are under warrenty if you can find a place that will sell them to you and then give them back to return. drop me a line if you need help
SOURCE: How can I resolve error code C-2451
Release new transfer belt unit
• A new installation is not detected when a new transfer cleaner unit (image transfer belt unit) is installed.
Remedy
1 Reinstall unit. 2 Check there is a short circuit in the fuse of the transfer belt unit. 3 Check the PRCB connector for proper connection and correct as necessary. 4 Change PRCB
Testimonial: "How can I get to the fuse of the transfer belt unit for konica minolta C550 and what is PRCB connector?"
