Simplest way to connect xenyx 1002 mixer to use the effects through a beringer acx1800 accoustic amp .thank you
SOURCE: whow i connect my xenyx 1002 mixer to audiophil 2496 sound card
You must connect:
the main out of the 1002, or the ctrl room out of the 1002 at your power amplifier's input.
the line in 9/10 of the 1002 at your 2496's line out.
the cd/tape out of the 1002 at your 2496's line in.
in case of a cd connect it's line out at line in 3/4, or line in 7/8 of 1002
some mic at the mic 1 or mic 2 of 1002.
That's the way you're going to have control for:
the mic level from channel 1 or 2.
cd level from channel 3/4 or 7/8.
pc playback from channel 9/10.
master speakers from main mix or ctrl room.
All the above connections are not absolute and may vary depending on your needs.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
