It is the Pump on your washer. The pump draws water to the tub, washes the clothes, then drains it! That is your problem. Now how to replace that Pump can be tricky easy and tricky Hard. If your scratching your head now...Call Sears repair!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
You need to vacume out all the water so you make it light, then dolly out the washer to some place you can drain it. now take off the front of the washer and locate your water pump, its attached to your drain line. take off drain line to water pump and see if anything is clogged in the pump. This is most likely what is wrong if it wont drain. hope this helps.
SOURCE: fisher paykel ecosmart washer wont go drain or go to rinse cycle
this is joyce
take hose and siphion the water out of the unit.run into pan on floor or outside if you have long enough hose. it will come out just get started by putting one end in water in tub and the other end outside or in tub or whatever and start suction on hose untill water comes out and let run untill all water is out of tub.
thanks,
joyce
SOURCE: ecosmart washer will not stop filling
It needs a new fill valve. These are not expensive and you can easily do this yourself.
SOURCE: I have a fisher paykel ecosmart wash cycle but when
Tip the Washer and check the hoses.... my husband just found 2 pennies stuck in one of the hoses in my F&P GWL15
SOURCE: I put heavy wool items in my ecosmart Fisher &
You should not continue to run the machine until you rectify the issue with the pump. Check the resistance of the pump's coil. It should be 7 ohms for the model GWL15. If the resistance is different, there is a problem with the pump electrically and it needs to be replaced.
