Sounds like AFT, AGC voltages are not proper. Contact any service technician. The main board of your TV has to be troubleshooted.
If the main system control memory IC is bad, this kind of fault can occur. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
SOURCE: Is there a way to access the T.V. menu without a remote?
YES YOU HAVE TO PRESS THE CHANNEL UP AND VOLUME UP TOGETHER OR THE CHANNEL DOWN AND VOLUME TOGETHER.THEN THE MENU WILL APPEAR AND DO WHAT YOU WANT TO AFTER,GOOD LUCK
SOURCE: 1999 sansui tvm1915 tv
You'll most likely need a Sansui remote made to work with your specific model TV. I have similar problems with my Toshiba TV. Check eBay.
SOURCE: manual buttons on set will only accept 3 channels
found solution by holding down both volume buttons at same time which enables on-screen menu allowing to select channel auto program
SOURCE: Up and down channel selection is not working.
From the menu select auto tune and scan the channels back into memory.
SOURCE: Have a sansui tvs273 tv. Need to switch it from
If your set does not have a menu button built into the set your out of luck unless you can find a replacement or universal remote.
