When you press the ''start''button the doorlock led blinks together with the wash led,but nothing happens after that.After a minute the display time stops.I did the daignostic test and got a F13 error.That meens the doorlock isn't working.I replaced it,but it didn't solve the problem.
SOURCE: Hoover Nextra HNWF 3137 washer/dryer
I have the same problem exactly please send me the solution with confirmation of the exact part requested my machine is HOOVER HNL3137 1300rpm/7kg thanks
SOURCE: Door Lock LED flashing
The solution from testy helped me but I decided to change it.
I cut the plastic latch away from the end of the interlock,just the little bar that holds the door closed.This means that the lock position doesn't affect the door.
I then used the little piece of plastic to act as 2 packing pieces to hold the lock half closed. This works fine.
Don't push the lock fully closed or it doesn't work
SOURCE: machine stops at spin cycle,
The symptons your giviong me poit to an issue with the pump probably not pumping all the water out like it should. Is this a top loader or front loader machine. In the mean time check and make sure the water is being pumped ourt completly before the spin starts.
SOURCE: Whirlpool Duet GHW9150PWO goes through
Hi F13 is a dispenser circuit error and is displayed if the
dispenser motor is not able to be driven to its proper position. Before
replacing the dispenser motor check the wire harness connections to the
dispenser motor and control board. Hope this helps...please post back for
further assistance. Daniel
SOURCE: My whirlpool Washing machine GHW9300PW1
Hi To unlock the controls press and hold the CYCLE SIGNAL/END
OF CYCLE button for 15 seconds. Hope this helps...please post back for further
assistance. Daniel
