Canon PIXMA  MP160 All-In-One InkJet Printer Logo
Angela cooper Posted on Feb 23, 2013
Where can I get a setup disc - Canon PIXMA MP160 All-In-One InkJet Printer
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Feb 23, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
3138
Points
24
In most cases I find that you can have disks mailed to you, they may charge for the disk and shipping. I would prefer going to the website and getting updated drivers since the drivers and software on the origional setup disk may be outdated
Canon Customer Support CenterHours:Monday-Friday 10:00 a.m. - 10:00 p.m. EST, excluding holidaysPhone:1-800-OK-CANON (toll free)
1-800-652-2666TDD:1-866-251-3752 (toll free)
1helpful
How do i select finalise on sharp dv-rw 250h remote control
If you are using the original remote or one which matches all of the functions, make sure that no DVD or VHS tape is being played and that the recorder is on. Make sure that there is sufficient space left on the disc. (The space needed depends on chapter/disc titles.) Then press Setup on the remote; it should be below the arrow keys but the position may vary. Use the Up/Down arrows to select System Setup and press Enter. Select Disc Setup and press Enter. Select Finalise and press Enter. Select Start with the Right/Left arrows and press Enter. Wait for the procedure to finish.
Note: only discs recorded on this particular device can be finalized on the DV-RW250H. On some other Sharp DVD recorders, the Disc Menu is accessed directly from the Setup menu.
I hope this helps.
Hyundai 320-A dvd player codes
Hyundai DVD-320A / DVD-360A / DVR-510C
  1. Method 1:
  2. Turn on the player (without a disc inserted)
  3. Press 7, 7, 0
  1. Method 2:
  3. Press 7, 7, PLAY
  4. Select region (0 = multi-region)
  5. Press SETUP
  1. Method 3:
  2. Open the disc tray
  3. Press 3, 8, 0, 0
  4. Select RC (0=codefree)
  5. Press SETUP
  6. Close the disc tray
Cannot record on Sansui VRDVD4005
Usually this would signal a bad disc, but if the discs have been known to be good, then your lens may be failing.
2answers
New computer with Vista operating system
You can download the setup wizard here:
http://www.linksysbycisco.com/US/en/support/WRT54GX2/download
1helpful
I cant figure out how to burn dvd after recording it?
put recorded disc in tray and let load
press setup on remote
use the arrow keys to the right of the setup button
press right arrow to highlight disc setup (on screen display)
press enter
use up down keys to scroll down to finalize disc
push enter
right left arrows for yes no
highlite yes then enter
disc will burn
I lost my setup CD-ROM. I cannot setup my computer without my CD-ROM
GO TO THE WEBSITE OF THE BRAND OF YOUR COMPUTER AND MOST TIME YOU SHOULD BE ABLE TO DOWNLOAD A SETUP DISC OR ORDER ONE AT LEAST. AT THE WORST YOU COULD GET AN OVERNIGHT DELIVERY ON A DISC AND BE BACK IN BUSINESS IN 24-36 HRS. THEN, MAKE COPIES OF THE DISC! BUT, MOST BRANDS WILL HAVE SETUP DISCS AVAILABLE. TRY THEIR WEBSITES. GOOD LUCK.
I have no setup disc for my hpc5200 printer
With regard to your setup disc, you may call printer manufacturer and request for a copy of your printer setup disc. You may also try downloading the printer driver from their support website.
Just visit their website at www.hp.com
keep me posted.
Thanks.
1helpful
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
1. (Open the disc tray)
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
6. A new menu entry appears (Version)
7. Select it and select RC (0=codefree)
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
DVD Burning doesn't work..no Disc in Setup..
Been checking out my m/c and found that there are many -r & -rw discs the m/c does not recognise which gives rise to this problem. However the m/c does recognise VERBATIM discs and I have been able to record and dub to them with no problems.
old marine
old marine
ZJ Limited
ZJ Limited
