Frigidaire FDF50S Dehumidifier Logo
Posted on Feb 23, 2013
Can't remove bucket on dehumidifier
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 04, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
915
Points
Afternoon,
I have the same model in my basement.
it sticks. sometimes it sticks so much I have to whack the sides of the bucket to jar it loose.
There are 2 places to grab the bucket at the top. using the palms of both hands, gently tap (or maybe more than tap!) these two latches. you may need to pry one side loose then the other will come out. you'll get the hand of it!!
The "bucket full" light blinks even after the
Eddie, turn the unit OFF & unplug it. Then remove the bucket and check the float valve in the top of the bucket. It may be stuck in the 'UP' position or is broken. When reinstalling the the bucket, be sure that it fit's "squarely" from top to bottom in the bucket holder and is making firm contact with the bucket safety removal switch on the rear wall of the bucket holder.
Hope this helped you and thanks for choosing FixYa.
The dehumidifier won't run. I adjust the humidistat up and down and nothing. worked fine up until that point.
Brad, there are several solvable things that can cause this:
1. The water collection bucket is not installed properly. Remove the bucket and reinstall it in such
a way that it fit's "squarely" into it's holder from top to bottom and makes contact with the bucket
safety removal switch on the back wall of the holder. When installed properly, the bottom of the
bucket will not tilt down at all.
2. The float valve in the top of the bucket (if yours is equipped) is either stuck in the 'UP' position or
float valve arm is broken. If it's stuck in the up position, jiggle the arm of the valve to make it
return to the 'DOWN' position. The float valve arm can be replaced if necessary. But in some
cases, you must purchase a new bucket with one already installed.
3. The outlet the unit is plugged into is faulty. Check your home's circuit breaker panel for a tripped
circuit breaker. If one is tripped, unplug the dehumidifier before resetting the breaker. If none is
tripped, check the outlet for power. It may have a loose or damaged wire on one of the terminals.
I hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
1helpful
It says it is full and there is no water in there and it will not run because it thinks it is full]
Usually when this occurs, the unit "thinks it's full', because either the water collection bucket is not installed properly or the float valve (if you model has one) in the top of the bucket, is stuck in the "UP' position.
Turn the unit OFF & unplug it. Remove the water collection bucket and check for the float valve. If it's stuck in the UP position, jiggle the handle to make it return to the DOWN position. Then reinstall the bucket, being sure that it fits into it's holder "squarely" from top to bottom and is making firm contact with the Bucket Safety Removal Switch on the rear wall of the bucket holder. If installed properly, the bottom of the bucket should not tilt down at all. Plug the unit in and turn it ON. If everything was done correctly, the Full Bucket Light should not illuminate.
Why does the full light stay on when the water container is empty?
It's generally cased by the bucket not being installed properly. Therefor, the bucket removal safety switch is not being triggered by the bucket, when it's reinstalled. Also, if you bucket has a float valve in the top of the bucket, it may be stuck in the 'UP' position. Is so, jiggle the float handle until it returns to the 'DOWN' position.
Reinstall the bucket so that it fits "squarely" into the holder from top to bottom. The bottom should not tilt down at all.
Hope this helped you to troubleshoot & solve the problem.
My dehumidifier says it is full but the bucket is empty. It will not work at all.
What you have described is usually caused by the bucket not being properly installed or if you have a model with a float valve in the top of the bucket , it is stuck in the UP position.
Turn the unit OFF & unplug it. Remove the bucket from it's holder and check for a float valve. If you have a model with that feature, jiggle the float valve's arm, to get it to return to the DOWN position.
If you don't have a float valve, the bucket must be installed "squarely'" into it's holder from top to bottom, so that the bucket makes firm contact with the actuator switch. The switch resembles a trigger switch, which is visible when the bucket is removed.
Troubleshoot the above, should solve the problem.
My dehumidified says its full but it is actually empty? what should I do?
The actuator switch, which is commonly called the bucket safety removal switch, is not making good contact with the bucket. Turn the unit OFF & Unplug it. Remove the bucket from it's holder and check the inside of the top of the bucket for a float valve. The float valve's arm may be stuck in the UP position. In which case, jiggle the arm to get it to return to the DOWN position. If your model doesn't have a float valve, look inside the bucket holder for what will look like a trigger switch. This is what the bucket must make firm contact with. Reinstall the bucket making sure that it fits "squarely" into the holder from top to bottom. When installed properly, the bottom of the bucket will not be tilting down.\
Plug the unit back in and turn the unit ON. If any of the above was corrected, the unit should turn ON and function normally.
Hope this helped you troubleshoot and solve the problem.
Fedders a7dh45b2a*a-r dehumidifier shuts off before the bucket fills
Actually, it's probably doing what it should. Let me explain: Dehumidifiers run until they have lowered the humidity/moisture level to where you have the humidity extraction level set. At that point, the unit shuts OFF, until senses the humidity level has risen above where you set the level and it turns ON again. That doesn't mean the bucket will always be full when it shuts OFF. It may turn ON & OFF many times before the bucket is full. Watch for the Bucket Full Light to illuminate. That's when the bucket is FULL and needs to be emptied.
Hope this helped you understand how the unit works.
LG DEHUMIDIFIER LHD459ELY9 LIGHT FOR "BUCKET
This usually caused by one of two things. The bucket is not installed properly or the float valve in the bucket is stuck in the UP position. The float valve is not in all models.
Turn the unit OFF & Unplug it. Remove the bucket, look in the top of the bucket on the left side closest to you. If you see a float valve you have that model. If the float is in the UP position, jiggle it so that it will return to the down position. Then reinstall the bucket. Plug the cord back in and turn the unit ON.
If you don't have a float valve, make sure, when you reinstall the bucket, that it fits "squarely" into the holder from top to bottom. When installed properly, the bottom of the bucket should not tilt down at all. The top, back side of the bucket must make firm contact with the bucket removal safety switch.
RED BUCKET LIGHT FLASHES OFF & ON HUMIDITY SAYS 01 NOTHING HAPPENS
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Will not run. low & high speed light on even on. no water in bucket
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Top Frigidaire Dehumidifiers Experts
john h
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
