Details I record drum/ bass and synth loops into logic and then send them to the rc50 loop pedal, i had 50 seconds of recording time left so i added a new track which left me 25 seconds of recording time, only for the loop pedal to tell me i had run out of recording time, i took another track out to make more room only for the loop pedal to tell me there is STILL no memory left, if i reset the loop pedal by taking all the tracks out to reset it, will that work to gather all the memory up and give me 200MB back again. Or is there any way i can add more memory to the rc50 loop pedal? Any way at all??? Please help.....
SOURCE: DP-01FX
I shut down the system, waited 30 seconds, turned it back on, and the recording went fine. Must've been a glitch.
SOURCE: I record using a pre
how long is the track you are trying to master i believe it has to be over 30 seconds if your just sampling 8 or so seconds it wont work i know on some models its over a minute to be able to master mix a track.
thanks,
Nate
SOURCE: record, playback problem
Hi Nick,
The fuzz/white noise is a little confusing and it seems to be saying that you are recording something vs trying to record incorrectly and getting nothing at all. Anyway, despite that, I would try going over your recording steps first.
First off make sure your Hi-Z input is not set to the Hi-Z or guitar setting. It is possible your that MicroKorg is overloading the input and distorting. You should however have heard that in the headphones too, so I'm not so sure that's the problem. The next thing to check is to make sure your input is assigned to the track you expect to be recording on. (Press the input's button to check this. The select/record button over the track should flash).
Next make sure your track is armed for recording before you press 'play+record' (Record button above the track should light steady when recording).
Hope this helps.
bd.
