Net-book / tablet shows start screen, but wont open menus, a lock icon in upper left hand corner says sorry
this means that the program you were running has crashed. If it happens everytime you launch a particular application then I would advise removing the program from the tablet and then reloading it
SOURCE: windows xp wont boot get
Ensure that there are no periferals plugged in, USB, Lan etc and take any disk out of the CD ROB drawer then try to boot again.
If it still doesn't work, you may have a hardware conflict and will need to press the F2 or whichever key for the BIOS menu and check that it is set up with Hard drive as first boot device, then try again.
Hope this helps
SOURCE: Acer Tablet C300 Series - Cursor moving to Left
i have exactly the same problem, returned my tablet 3 times and done fresh installs but it still occurs. each time i returned it they re-wired the wacom unit and it looked like it did the job but then started again a few weeks later. phoning acer up again to see whats happening as i'm still in warrenty. out of interest is it the bottom right corner when in laptop mode?
SOURCE: I have a Coby Internet
these might be the initial stages of the re-flashing process ie:installing the OS or upgrading when you might connect a usb cable,im not familiar with your brand.
SOURCE: screen went black on startup.
Does this problem occur after windows log in page? If yes, a file of your user profile may be corrupted. Try to do a system restore in Safe Mode if you can still access it.
If you're unable to boot to Safe Mode, then you might need to reinstall the operating system.
Let me know if this resolves your issue or not. Thanks.
