Have a Luxor tv for less than a year, but can't find my receipt to take it back. I can use the remote easily whilst watching tv but once I turn into DVD it will let me go to the homescreen, but none of the buttons except the power button work after that, so I can't watch DVDs. I used to be able to watch DVDs- how do I fix this problem????
SOURCE: I have a 20 inch TV/DVD combo 20HLV15. Last night
tiene que revisar el cable de AC de corrient ey si esta bueno tiene que de sarmarlo para que revise lo que es fuente de alimentacion de su tv combo
SOURCE: TV/VCR/DVD Combo won't turn on. Power button lights for 2 seconds
There may be some problem in the supply circuitry:-
1. Fuse is blown.
2. Transformer is burnt.
3. Power supply is faulty.
In either case I would like to add that Servicing TV is a very dangerous as it involves lethal voltages(around 25000 Volts). Please consult a qualified technician for servicing it.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
SOURCE: Panasonic PV-DR2714 will not turn on and i lost the remote
Hello Bobby
You haven't given enough details about the fault to your Combo. What do you mean my 'power button has coninuity on board'. I assumes that you get power LED at the front of your device lights up when you switch ON the main power switch, and the unit refuses to power ON and work further. If so, just make a factory reset to this set as it will reset the memory IC. To reset the unit to its factory reset do the folloing. But to do this, the power LED on the front panel of the unit should light up. Otherwise, the fault will be to its power regulator section. To reset the unit to factory reset:
[1] Turn the Power ON.
[2] Hold down both PLAY/REPET and FF on the unit more than 5 seconds. The power will shut OFF. Please ignore "NO CASETTE" warning.
[3] Perform initial set up refering to its user manual. You can see instructions to initial setup at page [16] of the user manual to your device. OK.
