SOURCE: Black shadow boxes on 46 in Samsung 46 in LCD HDTV.
Ur backlight video board is dying,must replaced to solved this problem.Part and labors about $500.
SOURCE: when i turn my tv on 3/4 of the right side of the
The problem is most likely in the image processor area, or the backplane circuitry on the screen itself.
The service rep would be equipped to properly service your set. You should call LG to find out who in your area is able to service your set.
If the set is out of warranty it could be fairly expensive to service.
Jerry G.
SOURCE: When I trun on TV (Samsung LN-T4661F 46 In), it
Samsung made a bad TV, the new part is $1200 I have the same issue. it is a blurred picture from left to right after about 10 min it goes away. (18 month old tv) it is only going to get worse.
SOURCE: My Samsung TV 46" LNT4671F
Hi:
This is due to low voltage getting to the Inverter board or the Inverter board on the bad side is not lighting the lamps. Usually bad capacitors or the power supply and the inverter will cause this symptom. You may want to replace both inverters boards on this model, new models have one inverter board for both sides of the backlight.
