SOURCE: top load lid repair
put one of the plastic balls in place on one side of the lid, hold the lid against it to hold it in place. then put the other ball in the other side indention and push the lid down on it until it pops in place. it is a little tricky if you have never done it b4.
SOURCE: Steps to disassemble Maytag washer's transmission mod LAT9704AAE
I had an outside service tech. to repair it . He replaced seals and bearings .
SOURCE: maytag top load neptune washer error code od
I own a maytag neptune, top load washer with electronic board or lcd screen, od code display, those are the door switches locates on the side of the door, the switches are electronic, an after opening the washer an opening the switches I discovered that the wire that sends the signal from the switches to the board were broken an rotted from the mold an soap that got accumulated in the switch, I took the switch an cleaned all the electric contacts, an stripped the wire back to were the wire was in good shape an re-solder the wire back to the switch, assembled back together an had the error went away ( no need to do anything else), the switches are attach to the machine with a 1/4 in screws , if you are not handy with soldering wires, you can order the part, ask for the lid switch give them your model number an I think they run about 75 dollars each, time to change em if ur a newbie, maybe an hour , I can do it in maybe 20 mins tops!
try it hope it works for you!,,,,,,
new washer 600
new parts 150
making a wife happy...............priceless!
good luck! let me know.
SOURCE: Top loading maytag washer leaking water during wash cycle
Hi, There are two spring clips located in the gap between the top and front panel. They are the edges.
If the pump and hoses aare ok, fill the washer with water and look up toward the center of the tub abd transmission area. It migth have a seal going bad.
I hope this helps.
Vic
SOURCE: Maytag top loading washer will not agitate
My rule of thumb: Take what you paid for the washer new and divide by number of years without repairs. That is your cost per year for the washer. If the repair will get you another year and is less than the number above do the repair. If you have done more than 2 major repairs in a year it is time to think new. eric
