someone might be trying to open unlock it before you did and tried too many pattern combination. it mights just be banned for couple of hours/min but you can try again later. too many attempts of wrong pattern/password can be interpreted as freud.
If you set a pass code (or pattern) that you cannot remember, please enter the wrong password (10-20 times) until you are prompted to sign in via your google account. Please note, this will only work if you have already setup your google account on the tablet. If you have not set up a Google (or Gmail) account on the tablet, you will have to perform a firmware install, which will revert the tablet back to factory settings.
There is nothing in the manual. http://www.kocaso.com/manuals/SX9700/SX9700_User_Manual.pdf
Try this before you do a factory reset by loading the firmware again.
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before.
