SOURCE: I need instructions for a LANDICE L7 LTD PRO SPORTS treadmill
You can get the manual on link below.
http://site.thefitnessoutlet.com/landice/LandicePTManual.pdf
SOURCE: landice 8700 sprint starts at full speed and then
This happened to mine and I figured out that the sensors were dirty. I got some canned air that you spray on computers and sprayed out the mother board. I also sprayed the electrical contacts with electrical contact cleaner and the treadmill is a good as new.
SOURCE: Landice L7 gives me a L5 reading on the screen
Your L7 error looks like L5 , but its really LS which mean lost signal. Unplug unit take motor shroud off then plug unit back in wall outlet. When looking in front unit you will see a Motor control board and there are LED lit up one of them should be an amber light this is you speed sensor which is attached to the top of your motor. Manually rotate the fly wheel and see if that light flickers if it does then your speed sensor is working properly if not replace speed sensor. The next thing to look at is the motor brushes to if they are worn unplug unit you should see slitted caps on both side of motor remove them if they are less than 3/8" they need replacing. That for the most parts should take of your problem. Call Landice @ 1800-526-3423 have the serial# handy their on all the components in the unit
SOURCE: landice L8 treadmill won't turn on
Check wall outlet for power , then if outlet is good unplug unit remove motor shroud you will see a charcoal or white ceramic fuse check it if open replace blows again immediately you have a shorted lower board. Here is the info Landice they help you with parts and get you in touch with a servicer if you need one.
Landice, Inc.
111 Canfield Avenue
Randolph, New Jersey USA 07869
(800) LANDICE
(973) 927-9010 - FAX: (973) 927-0630
[email protected]
SOURCE: Landice L9 Treadmill - Loss of Speed Signal Code
at starting, trys to go to speed and then reads LS on screen and runs very slow, with no response to any buttons.
