Did your computer come with windows 8 or did you upgrade to windows 8. If you upgraded, you will find that many of your old drivers will not work with windows 8. You can connect to the internet and check for updated drivers. I upgaraded and had to completly replace my wireless card because the old one was not compatible with windows 8. You can also make sure that everything is pluged in and restart your computer just in case your devices have not been discovered by your system.
SOURCE: Sony Viao keyboard - certain keys got wet & no longer work
well the damage is pretty much already done however you may try dabbing your keyboard with alcohol you can use quite a substantial amount use Que tips to get in between the keys.
I suggest getting it fixed
SOURCE: keyboard and mouse not working when windows starts
Hi there.
While you are in the operating system, unplug both the USB devices, then plug them back in, let windows recognize the new hardware and install it for you, this can take a couple of minutes, once it says hardware is installed and ready to use reboot the PC and see if you can use the keyboard and mouse while in the OS.
please post back with any more problems
Good luck and thanks for using Fixya!!!
SOURCE: windows update = dead mouse
Try using a usb mouse and keyboard.Your computer should already have drivers for these devices loaded.
