Question about SMC (SMCWBR14-G2) Router
SMC Barricade wireless router needs to be reset constantly
I have a SMC Barricade model SMCWBR14T-G wireless router which recently started freezing up several times daily and needs to be reset using the button on the back. It is about 2 1/2 years old. It is hooked up to my main computer's DSL via ethernet and wireless to a second computer. When it freezes, I lose connectivity with the internet until I reset it, then it works fine for a while. The router seems to be very hot on the bottom. Is this a settings issue, or is it simply nearing the end of it's life? It has worked fine up until now. Thanks for any help.
  • 1 more comment
  • Anonymous Apr 25, 2009
    I have the same problem with my smcwbr14-g2. It seems it is a little hot under and freezes when i try to download (movies, music etc). I also updated the firmware to version 1.11, it's the latest i could find on the web. If i connect the cable from my Isp directly to the computer i have no problem and the download is visibly much better, the router seems slower me a little.Also i must tell that the "freeze" is not regular, i mean the router works fine for a day, for a few days and once even for 2 weeks (and never for that time :D) or on the last weeks for 4-5 time per day. I'm thinking to change it but quickly than that remove it. Can anyone please help regarding this issue? Thankx
  • magnusi May 04, 2009
    Same as above, plus it is extremely slow at times.
  • vietbinh704
    vietbinh704 Feb 28, 2013
    I have used the same router with you and I have to re-power it twice a day, it usually freeze internet browsing.Binh
    Problem Solver:
  • 5 Answers
Maybe it is an electricity problem, or it's nearing the end of it's life. I bought 2 routers till now.each one worked fine for 2 years and then never worked.You should buy a new one or check if there's something with the electricity . Maybe a higher voltage
Posted on May 23, 2009
6ya staff
SOURCE:
How to reconfigure SMCWBR14T-G
http://www.smc.com/index.cfm?event=viewProduct&localeCode=EN_USA&cid=5&scid=26&pid=1441
Make sure the latest firmware is installed.
Nov 12, 2012 | SMC Barricade g SMCWBR14T-G Wireless...
How do you make your SMC router security enabled?
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Feb 17, 2011 | SMC Barricade g SMCWBR14T-G Wireless...
How to manually secure my SMC router
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jan 11, 2011 | SMC Barricade g SMCWBR14T-G Wireless...
I need to get the wep key, i cannot find it. thanks. model number: SMCWBR14T-G.
The computer is capable of reseting forgotten pass keys. Log on the computer administrators account,
Jan 10, 2011 | SMC Barricade g SMCWBR14T-G Wireless...
How to reset the router back to factory defaults
Unplug all the cables except the power cord.
While the Barricade is powered ON, Hold the RESET button for 30 seconds or as long as you find the Power LED blinks.
Feb 26, 2010 | SMC Barricade g SMCWBR14T-G Wireless...
Cant log into Barricade Admin software
Finally I found the reset button - on this model it was not on the rear panel but on the bottom covered with label and without any sign. Then I was able to reconfigure the system.
Aug 23, 2008 | SMC Barricade g SMCWBR14T-G Wireless...
SMC Barricade g SMCWBRT14T-G router
You need to open the port that Utorrent is using check this link for the step by step way on how to do that on the utorrent and on the router http://portforward.com/english/routers/port_forwarding/SMC/WBR14T-G/Utorrent.htm
Hope that helps..............
Aug 08, 2008 | SMC Barricade g SMCWBR14T-G Wireless...
Problems with wireless and uTorrent
Heres the webpage that will guide you through step by step.
SMC barricade g and timing out
just a few things that can be checked, firstly in the routers settings look at the transfer speed of the router(not the connection speed) and see if it's set at 108MBPS, if so your wireless network cards on your pc's may only be able to connect at a maximum speed of 54MBPS, unless you have the latest 108 or 125MBPS g type cards. Secondly you should be able to check the wireless signal strength by the icon in your task bar or software you use, as if you have thick walls or objects in the line of the signal from router to pc's, the strength drops and can read low and therefore cause you to lose internet connection entirely. You can also try changing the channel at which the router runs, normally this is channel 2, but trying channel 11, which is the farthest away from appliance interference may give you better results, but both router and network card channel numbers will have to be changed.
May 13, 2007 | SMC Barricade g SMCWBR14T-G Wireless...
SMC (SMCWBR14-G2) Router Logo
1,213 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Jeffrey Groves
Jeffrey Groves
Kris
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
